Home > Td5 > TD5 52mm Rev Counter cost !!
Page 2 of 3 <123>
dorsetsmith
on TD5 the input to the Rev Counter is from ECU ,not the ALT
Post #474723 20th Nov 2015 9:24pm
shaggydog
Ah fair enough.
Does the alternator not have a W-output you could use then? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #474724 20th Nov 2015 9:28pm
roel
no it hasn't. Roel
2003 90 Td5 (2009-now)
Post #474726 20th Nov 2015 9:35pm
shaggydog
Learn something every day Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #474732 20th Nov 2015 9:45pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
oh poo poo. I was close to ordering a w type one. Thank god i didnt! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #474752 20th Nov 2015 10:48pm
rallysteve
Pretty sure you can access the 'w' terminal if you remove the plastic on the back of the alternator. Its not a dedicated terminal anyway as such, just a point to pick up the un rectified ac waveform generated by the alternator. 02' 110 TD5 Double Cab Rebuild Thread
Post #474770 21st Nov 2015 6:51am
gazman
Hmm. Maybe this is worth me doing some digging. I'm going to add a homemade binnacle to the top of the dash between the fans so it doesn't matter if it's the same as the ones in the normal clocks or not. Maybe it's worth a punt on a really cheap one and I'll try it 2014 - current ..... 2003 defender td5 90 (my car)
Post #474778 21st Nov 2015 7:54am
chinnus
2001 Defender 90 Td5 ST Coniston Green
phoned them up and boltonbits are selling them for that price as they have run out of stock.....
Why they dont just remove the auction??
Post #474825 21st Nov 2015 12:49pm
Anderzander
Quite a lot of sellers do that. It must be easier to change the price twice than end the listing and open a new one - perhaps avoids any relisting fees too ?
Post #474836 21st Nov 2015 1:21pm
miker
got it in one! They can edit listings for free/cheap rather than paying for a new listing. Also means it stays in peoples watch lists, and if someone buys one at that price, all the better!!
Post #474842 21st Nov 2015 1:31pm
MaxRPM
shaggydog wrote:
You could try this?
http://www.ebay.co.uk/itm/Tachometer-0-600...XQVERSzrT~
I bought one for my Tdi which only goes up to 4k but must confess I haven't fitted it yet.
Unfortunately the TD5 requires a dedicated tachometer.
Post #475351 23rd Nov 2015 9:18am
rallysteve
Not quite sure where the basis for the blanket opinion that the td5 can only be fitted with a genuine tachometer.
As i mentioned the 'w terminal' can be tapped into on the alternator to run any tach designed for diesel engines with a tacho feed. There should be loads of choice in the marine world.
Second option is the use of some pretty simple electronics connected to the ECU pin 19 and the use of a petrol engine tachometer. Main issue with this is the RPM scale will be usually 8000rpm max.
Post #475374 23rd Nov 2015 10:43am
T1G UP
I got one for sale
Post #475378 23rd Nov 2015 10:51am
Martin
Site Admin
The Td5 rev counter signal is an emulated 4-cylinder pulse so it should be possible to fit a non-factory rev counter, set to 4 cylinder.
It might be necessary to do some level shifting to adapt voltage levels but nothing impossible. The Td5 pulse is 0-5V and the gauge might expect 12V pulses.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #475379 23rd Nov 2015 10:58am
rallysteve
Martin is correct, a simple transistor circuit is all that is really required to convert the 5v 50% duty factor square wave produced by the ECU to a 12v signal needed by coil connected petrol tachometers. This is quite common in petrol engine vehicles fitted with aftermarket ECUs (e.g. megasquirt) so a quick Google search yields the correct circuit.
Post #475389 23rd Nov 2015 11:52am
Page 2 of 3 <123>
