Home > My Defender > removing moss on your winch rope
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
has anyone any suggestions for a good way to stop the winch rope, which doesnt get used much, from going all green and mossy`?
I might make a cover up for it...?
rope not wire that is
CC
Post #475235 22nd Nov 2015 7:17pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
My winch is a warrior and they do sell neoprene covers for their winches, a quick search of eBay should bring some up. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #475239 22nd Nov 2015 7:26pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
To remove the moss, Throw it in your washing machine (When the other half goes out!) Wink
All our lowering ropes at work go through the wash every now and then, they come up lovely. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #475246 22nd Nov 2015 7:50pm
chopcat
Washing sounds a fine idea I will need to work out a way to wrap the eyelet bit to stop it demolishing the machine. A towel and cable ties should do it.
cheers
CC
Post #475345 23rd Nov 2015 8:57am
I use old socks when I wash things which have thimbled eyes or other metal bits to prevent the washing machine drum getting damaged.
Two or three old socks and a cable tie seem to work well.
Post #475352 23rd Nov 2015 9:29am
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Those must be large socks to fit a winch rope in Whistle
Post #475396 23rd Nov 2015 12:24pm
Triggerfinger
The dishwasher works a treat SSShhhhh Ive had all sorts in ours Laughing Do it right Do it once !!!!!
Post #475397 23rd Nov 2015 12:24pm
I rather assumed that the OP was asking about a synthetic rope, in which case only the thimble need be 'socked', which doesn't require a particularly big sock.
If it's a wire rope, it is probably best not to put it in the washing machine since it is likely to cause upset with the Domestic Authority when she finds out that the machine has wiped out the kitchen whilst self-destructing! Rolling with laughter
The sock trick has worked well with ratchet straps for me (not the ratchet mecanism though, before someone asks!), though you do get some scary noises from the machin even so, and you need to avoid the spin cycle.
Post #475419 23rd Nov 2015 1:26pm
Cupboard
Horse rugs make some very entertaining noises too.
My dad's had to get himself a "dirty" washing machine for all that sort of thing, for obvious reasons Very Happy
Post #475527 23rd Nov 2015 6:28pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Stick it in an old pillow case first Thumbs Up Adventure isn't paved!
Post #475571 23rd Nov 2015 7:44pm
