Home > Puma (Tdci) > Fuel filler hose size, ID?
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Installing a Webasto and Thermotop in my Puma and plan to take fuel with this kind of adapter.
This is really nice, but a bit expensive, so I will make my own as I need double pick-up.
My Defender is elsewhere and I can not go and measure the hose.
Would somebody tell me the hose iID? Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #475160 22nd Nov 2015 3:31pm
Td5
Finally got into this and the fuel filling hose has ID 50mm.
The Nakatanenga part has OD 60mm, it won't fit.
If you plan to take fuel for the filling hose, you should have >50mm pipe available
when you cut the filling hose. This at least for a 2007 Puma 90.
 Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #496459 26th Jan 2016 6:29am
Td5
Be very careful if you buy anything from Nakatenga, I have been waiting for a resolution
for this since January, only 3 months. Sent them a piece of the filler hose from my '07
Puma and the pipe that I bought. These people are crooks, and I have taken this issue
now to European Consumer Protection. This not about money, this is principle. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #525709 21st Apr 2016 10:35am
