Home > Maintenance & Modifications > Thermal Insulation and Adhesive |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 285 |
What is the best thermal Insulation material and adhesive to insulate a Puma? NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
19th Nov 2015 5:06pm |
Thanks RRUK, I'm currently investigating Thermaliner - http://www.harrisonstrimsupplies.co.uk/5-x...3173-p.asp
This appears to be a Closed Cell Foam with adhesive backing, anybody used it? NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
19th Nov 2015 5:43pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5108 |
Predictive text or spell checker strikes again Note: do not use dynamite to insulate, it does not work For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
19th Nov 2015 5:46pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Dynamat!!!!
2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
19th Nov 2015 5:47pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Thermal???I used typical household foil "blankets" on the doors/floor. I Noticed a difference,but when driving over the tops in high,high winds I could really feel the heat being sucked out of the door !!!So wear a good coat.
Honestly it was like a fan being turned on!!!! Pov.spec,ftw. 2006, 110,TD5. |
19th Nov 2015 5:56pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Dynamat for sound deadening and closed Cell foam for insulation...
CAMPING MAT - cheap and works well. Need to be careful in some areas that you are not adding too much extra depth otherwisw carpets and / or rubber matting will not fit as well as it did previously. |
19th Nov 2015 5:57pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
3m thinsulate!!! My 109 thread
my youtube channel |
19th Nov 2015 6:52pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
I used this stuff and have no complaints really does make a difference and easy to install.
http://www.ebay.co.uk/itm/5m-x1m-THERMOLIN...4aefee2d4c There are some more pics in my gallery of the install and finished article Click image to enlarge |
19th Nov 2015 7:01pm |
Radhaz stuff on eBay is a good thermal insulator, I used it under my battery box and in footwells for an arctic trip, we had overnight temperatures of -38c when stationary. To be honest the puma has a brilliant heater and does not need much except the rocker cover to airbox heater mod and that's only when you get to temps of less than -20c
Odyssey batteries are good to -50c |
19th Nov 2015 7:40pm |
Click image to enlarge Given the money some seem happy to splurge on their motors, I'm surprised this has been seen yet. Last edited by Supacat on 20th Nov 2015 8:41am. Edited 1 time in total |
19th Nov 2015 8:51pm |
could you give me more infos about this mod? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
19th Nov 2015 8:58pm |
Daniele
I will send you a PM Bpman |
19th Nov 2015 10:23pm |
That's just a 2.4 engine issue isn't it?
20th Nov 2015 8:42am |
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 |
Can you please give more info? Thanks. |
20th Nov 2015 9:21am |
