![]() | Home > Maintenance & Modifications > Britpart twin shock kit |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 ![]() ![]() |
Terrafirma do twin shock mounts some on ebay for pics
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Better to go for a single uprated shock. If you need more than one standard then replacing it with two standards makes little sense.
If one goes then the second will be overloaded instantly, better to rely on a higher spec item from the start. |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
Foleys do a twin shock mod often it seems. Britpart sells the kit. Top shock mounts and weld-on tabs for the axle.
I have some take-off dampers and the kit is fairly reasonable. Just tips about the fitting the top mounts and is welding the axle tabs straight forward ... |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Based on this logic......if you have one single "uprated" shock and it goes then you have no damping on that side. It would seem that on a twin shock set up you are better off if one shock goes as you still have some damping..... I also consider that not all aftermarket shocks are an up grade on the Standard Genuine LR Shocks. Another thing to consider is that if you mostly drive your vehicle on good roads with light loads then you may be wasting money trying for an upgraded shock and if you do upgrade you will most likely be impressed as you are usually replacing an old shock. Shocks work hardest on loaded vehicles used on fast rough roads - like you find in Africa not UK. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
