Home > Maintenance & Modifications > Wiring Spots (no snorkel) |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Looking at the option of getting some spots on the roof rack, most wiring options are where you guys have gone down or inside the snorkel, I do not have a snorkel. looked about a bit on the forum and I am sure this topic has been covered before, can someone direct me please
TACK |
3rd Dec 2010 8:08pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I have a snorkel fitted, but when I get a roof rack and spots thought I would go down this route of wiring them up as I would want to take the rack off when its not being used in the winter time:
http://www.entreq.de/products/electrical-e...ungen.html TheBoy has some good threads on wiring up spots: http://www.defender2.net/forum/topic3564.h...pot+lights |
3rd Dec 2010 8:39pm |
Cheers Brian, so long and short of it looks like I need to go through a panel somewhere to bring the cables in
3rd Dec 2010 9:08pm |
Afraid so, then again you could always fit a snorkel. Believe Glynparry25 recently had one for sale
3rd Dec 2010 9:36pm |
ummmmmmmmmmmmmm
avoided getting a snorkle as over confidence will see me getting wet feet |
3rd Dec 2010 9:44pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
MAN up and get a snorkel you poof 130's have feeling's as well you know
3rd Dec 2010 10:26pm |
Diplomatic as usual Andrew |
3rd Dec 2010 10:28pm |
oh hello Don't really need a snorkel, want some lights though for night work. If i ever need to go into deep water I will call you as I will end up being one of those dick heads, I honestly dont see the need for one as the last time i was near water with you I think it was my right foot which had a problem not the depth of the water |
3rd Dec 2010 10:47pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
With a roof rack and no snorkel you have various options. A watertight connector and go through the roof by the A pillar. Alternative is use superseal connectors then take cabling along roof rack and then down the ladder and along the chassis. Hope that makes sense Brendan |
3rd Dec 2010 10:59pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Without wanting to ask dummy questions, can I ask what needs to be done to auxiliary light wiring once it's inside the engine bay? Where have you guys wired it into. Is there a socket as there is for trailer wiring? Or is it a question of grafting on to current wiring?
I'd love to do this job myself, but i am a limited mechanical electrician! The limit of my skills was plugging in the trailer electrics and rewiring my old Sankey. |
11th Dec 2010 6:43pm |
First thing is to work out the current to your lights. Easy calculation from Current I = Power/12 volts. That is power per lamp and they are normally switched in pairs. This figure then defines the cable and fuse rating with an appropriate safey factor.
Most lamps will be switched via a relay which can be located in drivers seat box. If wired separately from headlights then the spotlights are not legal for road use in UK HTH Brendan |
11th Dec 2010 7:54pm |
