![]() | Home > In Car Electronics > ICE Upgrade - Alpine IDE178BT, Focal Speakers and Focal Sub |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 ![]() ![]() ![]() |
Hi Rosco,
After much thought I went in behind the vent. I had the dash panel off anyway and cut a small groove on the top edge of the remaining dash. Just enough to slide the wire in and refit the dash panel. The theory is that if I remove it, the hole will be barely visible on the top of the dash ![]() Click image to enlarge John |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
John,
Thanks for that. That will be my method if plan A doesn't work Rosco 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
I've just installed the same head unit in my 2003 TD5 110 CSW, the sound from the rear speakers is absolutely rubbish, then I realised I don't actually have any rear speakers !!!
