Home > Td5 > Key fob battery change
Martin 01
Just changed the battery in my key fob, now it doesn't seem to work at all.
An ideas ?
I'm sure I read some where there is a sequence after changing your battery.
Any help greatly appreciated from you knowledgeable chaps. Thumbs Up
Post #472740 15th Nov 2015 6:21pm
K9F
It is in the owner's handbook.....
See post four.....
http://www.defender2.net/forum/topic37269....+procedure If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472751 15th Nov 2015 6:37pm
mk1collector
Did you take the sticker off the battery? Someone posted on here this week that they changed the battery and missed a sticker that had been put on the bottom to stop young kids eating them Rolling Eyes because a sticker would make a difference Rolling with laughter Ray
My build thread
Post #472753 15th Nov 2015 6:41pm
Laurie
When my repairer changed the battery in my keyfob he just took it out of range of the vehicle and did a quick swap.
No masonic ritual involved. Worked fine.
Post #472773 15th Nov 2015 7:10pm
K9F
TD5s appear to be less irksome with no necessary 'resync' often required? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472774 15th Nov 2015 7:12pm
Martin 01
Thanks for that K9f.
Problem is I've already just replaced the battery without unlocking the vehicle first.
I've now opened the vehicle with the key but the alarm keeps going off.
I've put the keys in to fire it up & nothing.
Any ideas ?
Post #472775 15th Nov 2015 7:13pm
Martin 01
All I've done is quickly change the battery in the house which is away from the vehicle.
Gone out to open it with the fob & it won't open.
Post #472777 15th Nov 2015 7:15pm
dorsetsmith
immobiliser is probably stopping it from cranking, is red engine light flashing with a line through on the dash Question if so the immobiliser locking you out
Post #472785 15th Nov 2015 7:23pm
K9F
If you've a spare functional fob, remove the battery from the one you have just replaced, using the spare fob lock and then unlock the vehicle with this and start again? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472787 15th Nov 2015 7:24pm
Martin 01
Now in the vehicle, put key in & turn it to fire it up & red engine light flashing up.
Baffling me.
All this for a simple, so I thought battery fob change. Big Cry
Post #472789 15th Nov 2015 7:25pm
Martin 01
That's what is happening now.
Any ideas where to go next ?
Post #472790 15th Nov 2015 7:27pm
K9F
Spare fob if you have one? Alternatively disconnect the main battery with the key fob battery removed, leave it for a few minutes reconnect main battery, insert battery into fob and try 'resync' procedure again. Either way you have nothing to lose as it's immobilised as stated. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472793 15th Nov 2015 7:30pm
mk1collector
Check battery is in the right way and fully in place, if so replace with old battery and see if the fob works again. Could be a duff battery. Ray
My build thread
Post #472794 15th Nov 2015 7:30pm
Martin 01
I'll give it a try.
Thought changing the battery would be simple, obviously not. Big Cry
Post #472807 15th Nov 2015 7:48pm
Martin 01
All back up & running again now.
Disconnected battery for 10 mins, reconnected it, went through the installation guide & hey ho all done.
I'll remember to read the installation guide next time BEFORE I change it. Embarassed
Thanks for all your replays guys, greatly appreciated. Thumbs Up
Post #472814 15th Nov 2015 8:13pm
