Home > In Car Electronics > Reverse light/cam dead? |
I don't know where the fuses are for a Puma but a look in the manual will guide you, if you haven't got a manual then a google search will help.
Before I would go looking at fuses I would be having a look at the join you made to join into the reverse light circuit and double check all is good. If you joined near the switch on the gearbox then double check it's all connected. |
12th Nov 2015 11:45am |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Check the Earth on the camera .....
12th Nov 2015 1:49pm |
What current draw or power rating does the camera have? This should naturally have been taken into consideration before powering it up.
Reverse light is fuse 14 rated at 10 amps Central Junction Box P101 as marked on the diagrams. Without the above information we could speculate all day what the replacement should be upgraded to if it has in fact ruptured. For information the reversing light shares its earth with the left hand tail light (and the number plate light on some models) for diagnostic purposes. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Nov 2015 2:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Also depends if the reverse is LED or not.
If it is then there is more spare current capacity compared to a regular incandescent bulb fixture. Typically refers cams are under 1A normally but none the less not something to take for granted. I also agree with the above if the likely hood of it being a loose connection or earth or both. |
12th Nov 2015 5:00pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
I used this to wire my camera to reverse light
http://www.mudstuff.co.uk/products/electri...-loom.html Last edited by Romadog on 12th Nov 2015 6:12pm. Edited 1 time in total |
12th Nov 2015 5:45pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5112 |
Thank's I have been looking for something just like that For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
12th Nov 2015 5:55pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
Personaly I would of used the Rev light as a trigger for a relay to be on the same side then you could add extra rev lights at a later date
12th Nov 2015 6:03pm |
110-Utility Member Since: 30 Sep 2015 Location: Devon Posts: 47 |
The rear lights are indeed LED lights.
I didn't do it near the gearbox, I removed light cluster and spliced into wire here. I'm pretty sure the connections are good, used crimp connectors and checked them last night. Rear left taillight and number plate light still work fine |
13th Nov 2015 9:25am |
