Home > Puma (Tdci) > Cam timing |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Easy,
Remove the timming chain cover (not that easy) Remove the crank shaft position / speed sensor. Turn the engine to tdc on number 1 cylinder. If correct the two cam gears should have window in each at either 6 or 12 o`clock (sorry used to transit / ldv engines) in to which you should be able to push a 6 mm (ish) drill bit. thru the gears into the head. That's the cams lined up. The fuel pump gear should have a similar window to put a drill bit into. Then into the block. Pump gear lined up Once the crank sensors out you can push a 13 to 15 (ish ) mm drill bit into the mounting hole. Then into a larger slot on the flywheel it`s self, the mounts made from ally I think. so don`t use it to lock the engine for tightening the crank pulley bolts. Unless it`s 180 degrees out you won`t have to turn the engine over again to line all the marks up. You can get a timming pin kit but drill bits are cheaper !! Excuse the spelling I`am better with spanners and wires. |
12th Nov 2015 10:56pm |
