Home > Puma (Tdci) > Wiper spindle question
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
hi, this morning i forgot to make sure the blades were free and not stuck. the o/s was and when i switched them on the n/s worked as usual. i quickly switched off and freed up the stauck one but it is now looser.
i tried to tighten up the nut but i think i have knackered the splines, so the question is do you know whether i would have ruined the splines on the shaft or on the wiper arm.
hopefully just the wiper arm!
thanks BM52
Post #47101 2nd Dec 2010 4:44pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Just the arm - they are softer than the spindles - although you can just buy the spindle top as well.
Post #47119 2nd Dec 2010 6:25pm
bm52
thanks, i'l get a new arm first before i tak it off just in case the old one won't go back on... BM52
Post #47135 2nd Dec 2010 7:10pm
bm52
new arm seems to be the same as the late TD5 with a nylon ring inside which is compressed on the shaft splines. £11 and 10 mins later all fixed.
regards BM52
Post #47493 5th Dec 2010 5:30pm
