![]() | Home > Tdi > Advice please - 300Tdi clutch pedal spring |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 ![]() ![]() ![]() |
Hi all,
So, having had the Defender for a few months I've developed a left leg like Popeye's arm (less the tattoos). It's a 1998 300Tdi hard top. I've been looking at the various threads about the clutch pedal spring and as far as I can make out the pedal didn't get really firm until the Td5. I've had a look at the spring currently on the pedal and it looks very similar to the modified version for the Td5. Can someone kindly confirm whether the 300Ti would benefit from its standard spring or do I need to buy trousers with a bigger left leg? Thanks everyone. ![]() Andy |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 ![]() ![]() |
Ya wimp what you need is a stronger spring for the accelerator
Buy a foden recovery truck and use that for a while, the defender pedal will seem like thin air
![]() On a serious note since I have replaced the slave cylinder and had to bleed it through my pedal is lighter, might be worth bleeding it. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
If you keep having troubles with a heavy clutch you could fit a RedBooster Clutch Servo... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
I changed a couple of 300tdi clutches due to being heavy, as they get nearer to the end of there lives they get heavier.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Thanks for the advice everyone.
![]() Appreciated. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
Hi just found your thread, ive got a 300tdi and my clutch was heavy and hard, so my repair man was trying a different type of clutch from the normal Borg-warner one and as a few have said who have driven mine, say that its like a car one, nice and easy with no effort, but i remember was make it was, can find out if you want to know ? hope it helps you
Nice one. Thanks L110CDL.
Yeah, any info about the clutch would be useful. |
sorry its been a few days trying to get to get on the laptop, the clutch kit for my defender is VALEO, im not sure if thats spelt right, hope it helps
Thanks chap.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Changing the clutch in my 300tdi 90 made it significantly lighter, a good excuse to do your rear crank seal if it's leaking also. Like L110CDL I used a Valeo kit.
Harry |
totally agree Harry, good time to change the seal
Yo init,
Rainy weekend so tackled the replacement of the clutch pedal spring. Definitely an improvement - and a quick job using the suggested method elsewhere on the forum. Must of took all of 30 minutes and that included a cuppa builders. A happy chappy. ![]() |
