![]() | Home > Puma (Tdci) > Alarm not working? |
It could be the perimetric sensors have been switched/programmed off. Take it back to the dealers for diagnosis.
![]() Treat every day as if it is your last....one day you will be right!! |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 ![]() ![]() ![]() |
Thanks K9. Will ring the dealer and see what they say
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Lock it and stay inside it for 5 - 10 minutes then move and see what happens. Mike
Thanks mse, 10 minutes after locking and movement sets the alarm off. That teaches me to be more patient next time I'm looking for problems!
No problem
![]() I seemed to remember it took longer and didnt always respond to a arm through the window (i think i did it on a past LR car...probably a disco). At least it didnt cost you anything either ![]() ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2297 ![]() ![]() ![]() |
mse you are right...
![]() Thought I'd check mine and the Alarm activates with internal movement at around 6 Minutes after setting... ![]() Why ... Anyone got any knowledge on this... ![]() https://www.defender2.net/forum/topic83242.html |
