Home > Maintenance & Modifications > So if not warn |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 824 |
Hi,
Take a look at the Roo Lite or the same but more expencive Light Force lights - they offer several sizes and types and have the option on them to change from a spot to a wide spread simply be rotating the outer cover They are fantastic and look good also Cheviot 4x4 sell both and they are on 0191 2574444 or look on www.cheviot4x4.com Hope this helps. Russell. |
14th Nov 2008 5:04pm |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
LIGHTFORCE DEFENDER XS CSW 08 TONGA GREEN
14th Nov 2008 5:39pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Thanks - how are you guys mounting them - a bar, floating bar or something else?
Are we talking these: http://www.cheviot4x4.com/shop/Products/Li...ite%20180/ £58 *2 isnt bad if they are good Mike |
14th Nov 2008 5:45pm |
they are fairly small i think, i was looking at the striker 170's and fitted under a soft foam A Bar on a new defender ! DEFENDER XS CSW 08 TONGA GREEN
14th Nov 2008 11:00pm |
I think i will be doing that then - just got to think of the mounting method.
Have to wait until December just bought myself a little travel notebook. So i have a monthish to work it out before im in Scotland Mike |
15th Nov 2008 12:00am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Careful with the mounting of the 170's if they are the jointed arm like the Lightforce they can very easily be destroyed.
Don't know what Hella are priced like in UK (they're expensive down here) but the Rallye 4000 FF Compacts are very good lights to. Had them on my Disco2 and they were about the same as the older larger size (8") 4000's. Oh and the Lightforce 240HID's I've got on my Puma are fantastic 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
15th Nov 2008 1:07am |
The choice only seems to get bigger!
Life was easy when i wanted the Warn lights, i knew the ones and where to get them from - now im like a cat in the lights of a range of spotlights! So if found the roo lites from Cheviot seem good. Hella - ive experienced, good - but where to get them KC lites - i like, from matt savage i think Lightforce, as advice they look the same as the roolites, just more expensive Choices... Mike |
15th Nov 2008 10:05am |
I would have bought the ROO lights to be honest if i would have seem them especially at £60
i got what i thought was a good at the time paying £175 for LIGHTFORCE as everywhere was selling them at a tad over £200, again as oposed to the WARN at the best part of £300. the most contributing factors involved in choosing the LIGHTFORCE for me were ! Anti corrosive body and reflectors, stainless fixings, LEXAN impact resistant lense which also have the protectors to cover them combined with this is the differing lense combo's to project beams and alter colours to suit driving conditions. Most importantly the projected beam is like a light sabre lighting up the track way ahed of anything that could be deemed too close for comfort. DEFENDER XS CSW 08 TONGA GREEN |
15th Nov 2008 11:10am |
Thanks for that mate.
Its decided then Roo Lites - they seem to have some similar features to lightforce for about £80 less. So on to mounting the things Mike |
15th Nov 2008 11:36am |
Mounting them !
i have the soft rubberised foamy type A bar and they dangle under that very well. If you are intending getting a winch as i think you have said you are then you can get these with centre bar removed to accomodate a winch. Fitting kits come included with these lights and look very substantial indeed, heavy duty wire and in line fuses and a Digital switch ? whatever the digital switches are ? DEFENDER XS CSW 08 TONGA GREEN |
15th Nov 2008 12:43pm |
Ive got a winch my problem is im not 100% taken on the a-bar but it will probably have to be that. Mike
15th Nov 2008 8:35pm |
