Home > In Car Electronics > Correct way to splice wire
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
For the auto electricians on here. What is the correct way to pick up a feed from another wire? I have always used one of two methods
1 strip a small part of wire and wrap the new wire in and tape up
2 scotch lock
I know scotch locks are not liked but are very easy but number one don't seem much neater so wondering what the 'official' professional way is.
Post #470506 7th Nov 2015 9:22pm
Martin
Site Admin
Scotchlock - no way. They are unreliable, and allow moisture into the core of the cable Rolling Eyes
Number 1 only if you don't mind it coming undone Shocked
Number 1 plus a dab of solder is not bad.
Personally I would cut and re-join with solder and heatshrink covering up.
LR use these extensively in accessory fitting and I keep meaning to get some to try:
http://www.polevolt.co.uk/acatalog/Jointing_Terminals.html (top 2 products)
Cut the wire, strip the ends, insert all three and heat with a hot air gun.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470510 7th Nov 2015 9:29pm
Mo Murphy
Those are good! Well found Martin.
50 Shades of Pennine Grey
Post #470514 7th Nov 2015 9:35pm
Sphere
Look super think I may be ordering some of them!
Post #470518 7th Nov 2015 9:46pm
mick
I've never had much success with the heat shrink solder things I prefer a dab of solder then heat shrink over it.
Post #470529 7th Nov 2015 10:09pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Handy - thanks Martin. Reminds me of "Sleeves, self-soldering". Shows my age - anyone else remember them?
The other thing worth investing in is the rubberised cloth tape used by LR in all their looms. With a little effort you can add extra accessories to the loom that are alomst indistinguishable from original wiring. That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #470539 7th Nov 2015 10:29pm
Martin
Site Admin
TESA harness tape Thumbs Up Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470540 7th Nov 2015 10:32pm
K9F
Cut and paste from an identical thread. Crimps are noy unlike Martin's but you need the tool as well.
K9F wrote:
Not an auto electrician but a marine one..... Whistle
Hermetically sealed in-line splices are the best. There is a sleeve that is preformed with resin at each end that when you apply heat the sleeve shrinks and the resin melts making a 100% waterproof seal. I have bucket loads of these and can send you some in the post. You do need a crimping tool but you may be able to adapt if you have a crimping tool already. Alternatively if you are near Falmouth and can wait until the new year I will be down in January for dry dock for a few days and can lend/give you all you need. PM me if I can help. Soldering is not a bad idea too but I would use slightly larger heatshrink and smother the job in Sikaflex then shrink the heatshrink and allow the Sikaflex to go off, this will also ensure the job is waterproof.
The blue crimp depicted is middle size, there is a smaller red and larger yellow available dependant on cable sizes. Thumbs Up
http://uk.rs-online.com/web/p/crimp-butt-s...s/4445665/
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470543 7th Nov 2015 10:39pm
mick
You could send me some Whistle please got some re wiring on the rib this winter that I'm not looking forward to also doing the led submersible lights on the trailer Thumbs Up
Post #470559 7th Nov 2015 11:11pm
K9F
PM me your address and I'll dig out a few. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470567 7th Nov 2015 11:43pm
mick
Thanks
Post #470607 8th Nov 2015 8:48am
ericvv
Why are the red in both depicted cases for 0.5-1.5mm cable and both of the blue for 1.5-2.5mm cable, with no other size options available? Does blue by definition have to be bigger diameter cable?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #470615 8th Nov 2015 10:08am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I believe the crimps are colour coded by size, red, then blue, then yello. The colour is not there to differentiate between live and Earth. Poor choice of colour, but that's life! Use the cable colours to indicate the purpose of the wire! Plus, if you crimp, you could always heat shrink over the crimped connection like I do if I'm using a terminal, that way it can't be seen. Failing that, if your joining cable as opposed to terminating cable, solder them neatly and heat shrink.
Post #470619 8th Nov 2015 10:16am
JAY BOY
Wales
ericvv
red crimps are up to 1.5 mm cable
Blue crimps are from 1.5 mm-2.5 mm
Yellow are 4mm - 6mm
That is the largest insulated crimps you can buy. After that they come in Non insulated which you would slide heat shrink over and insulate that way.
Thumbs Up
Post #470622 8th Nov 2015 10:20am
VeeTee
Netherlands
Red, blue, and yellow (Who is afraid of red, yellow and blue? Laughing ) are the standardised colour codes for terminals for the wire diameter:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #470628 8th Nov 2015 10:39am
