![]() | Home > Maintenance & Modifications > Range Rover Evoque front seats in a Defender? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Wouldn't they be too advanced/technical and require some kind of link to a higher end ECU for the airbags, remote adjustment etc? Not to mention the price. I bet you they would cost more than even a pair of equivalent Recaros which we all know fit well.... Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
A mate of mine has RRS seats in his defender. Wiring to the seat was pretty simple allowing all the adjustment to work. Airbag is still inside the seat but not connected so is in effect just ballast now!
Vanderbult Member Since: 28 Oct 2015 Location: amsterdam Posts: 20 ![]() ![]() ![]() |
You Thank it's possible to get some pictures of those RRS seats in a defender? Because I think the seat base of those seats are even higher.
I've done some research and all the electrical stuf is build in the seat, so all the movement would be possible if I wire up the 12v to the seats. Of course the airbag won't work though. |
I don't like the look of the recaro's and there is a scrapyard close to where I live which is specialized in Range Rover parts, they have a couple of seats from crashed evoque's. Which I do like the look of, I think it's just a matter of hooking up the power to the seats since all the electricals are build in the seat. |
Pop along with a tape measure or even with your defender, as it takes only 10mins to pop the front seats out and you can lift the evoque seat in, and if someone holds it from behind, even practice sitting in it. Then you'll know not only that it fits, but if it 'looks' right...
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I'll try to get some photos of the RRS seats in the defender..
Thanks
So turns out the seats are to wide. too high as well but the seat base wasn't that compact so i figured i could change that, but because the seat is so wide that the seating position changes to much towards the center of the car.
I've done some digging around and the best i could find that would fit are porsche seats and from a smart for two. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Try the seats of a Citroen Xsara Picasso...
No a Porsche one but if you are looking for comfort are OK I seen some Defenders with those seats in Argentina. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Personally I find the defender seats very comfortable... Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Think so too. Nothing wrong with those Recaros. ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
jesperjes Member Since: 26 Dec 2013 Location: Denmark Posts: 9 ![]() ![]() |
I have recently installed Mazda RX8 seats. Those are REALLY comfortable!
Also, the seat control module on Evoque seats is coded to VIN, so will only work on that Evoque, it's not as simple as supplying a 12V feed. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
