Home > Technical > Rear Heated Window and Brake Lights issues?
Defender-Stu
Ok so if anyone could help that would be great,
So got in my X-Tech this morning to go to work and put the rear heated window on and the 2 body mounted brake lights( OE LED LIGHTS) came on and stay on until I turn the heated window back off? The brake light all work as they should with the pedal and everything else seems to work as it should on the back end so could I be right in saying its a relay maybe?
Thanks for you help in advance
Stu
Post #469959 6th Nov 2015 7:13am
JWL
Sounds like an earth issue on the rear window glass. At the base of the glass there are a couple of tab connectors that join the printed circuit of the heated screen. One of these will be heated screen power, one for the high level brakelight and then another for joint earth. It is common for one to be knocked and not give a contact.
They can be re-attached or with the earth you could run another wire from the brake light to act as a bypass
Post #469965 6th Nov 2015 7:51am
Defender-Stu
Ok mate im popping to my mate who is a LR Indy later to use his tools so will see what i can do Thumbs Up
Post #469977 6th Nov 2015 8:27am
Definitely an earth fault of some kind, I'd say.
Check all the rear lights in combination with each other, I wouldn't be at all surprised if there are odd results. Check the earth connction in the vicinity of the offside transfer box mounting bracket (this is the main earth point for the rear end harness).
Post #470038 6th Nov 2015 10:56am
Defender-Stu
Ok so need to check the Earth from each brake light and the Rear screen, shall i put say white grease on the connections?
Post #470049 6th Nov 2015 11:13am
Defender-Stu
All sorted and cheers guys for the help Thumbs Up
It would help if it wasn't un plugged, so that was me cleaning at the weekend lol
Post #470110 6th Nov 2015 2:08pm
JWL
It's so nice to find the easy fix Thumbs Up
Post #470113 6th Nov 2015 2:14pm
