anyone with a D3/4 or RRS can measure this?
I need to know the distance between the head rest stems, front and rear, from the centres of the stems.
I am looking to replace the head rests on the front seats in my Defender with ones that can tilt forwards to provide neck and head support, but the Range Rover L322 are too close together.
Don't know if it's actually of any use, because the D3 headrests don't adjust, but I've measured them all the same:
Fronts I've measured as 151mm (but, probably not surprisingly, a voice in my head is determined that it must be 150mm... ), rear outers are 160mm and the rear centre is 120mm.
Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
3rd Nov 2015 2:57pm
1967jester
Approx 14cm inside, just measured the D4, will try a better look tomorrow when light better & I can find my glasses
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
