Home > Td5 > Starting Glitch
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Starting Glitch
For the past 2 days my 90 has been behaving strangely after being left overnight.
When i try to start it, it fires up instantly as normal and then is running extremely rough for about 5 seconds sounding like it's about to stall. It then begins idling normally and all is fine. I can leave it all day and it fires up again fine.
I changed the fuel filter head last night and let the pump run for 3 lots of 30 seconds to prime the system and after this it fired up fine first time.
The only thing is first thing in the morning the pump does sound like it's trying to bleed a bit of air. Not sure if it would be worth running a proper purge cycle (accelerator 5x during the ignition sequence i believe?)?
Can anyone else think what it could be? It's odd it was working fine with no issues until yesterday morning all of a sudden.
Post #468931 3rd Nov 2015 7:49am
MAF sensor.
Try disconnecting it Thumbs Up
Post #468932 3rd Nov 2015 7:54am
Freypal
Recently replaced the MAF with a genuine VDO. Noticeably worse performance whilst driving with it unplugged so seems good...
Post #468948 3rd Nov 2015 8:56am
Ahhh, thats all my mechanical know how used up - sorry
Post #468949 3rd Nov 2015 8:58am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Very possibly, an injector dripping fuel overnight, or an injector loom issue
If it was a burst injector seal, the fuel would drain out the head completely
As its only a rough idle, this would point to a single injector issue, be it mechanical or electrical
Post #468951 3rd Nov 2015 9:04am
Freypal
One other symptom which I'm not sure about is it did seem to be putting out white smoke/steam for a minute or so after starting up. However as the mornings have been cold it didn't seem much different to a normal amount you'd expect. Just that I've noticed it.
Difficult to tell though as it could just be the cold... As id expected to see some on colder.mornings.
Post #469009 3rd Nov 2015 11:42am
Freypal
When you say injector seal do you mean the copper washers or an o-ring within the injector assembly itself?
Other thoughts i had were;
Fuel Pressure Regulator - this has been weeping for some time. Not sure if this would allow any air through though sufficiently to give a rough start.
Glow Plugs - Maybe on the way out on a cylinder
Worst case - water in a cylinder causing rough running at start until it burns off - would indicate a head gasket or cracked head - will check the oil condition tonight. I serviced the truck a week ago and the old oil came out fine and didn't smell of diesel.
Purging the fuel rail - Given that the car will start and run fine once the rough idle is over - i assume there is little point trying to prime/purge the manifold any further? I would have thought that running the truck for any period of time would purge any remaining air from the fuel system?
Post #469027 3rd Nov 2015 12:48pm
Martin
Site Admin
The air noise you are getting suggests your FPR leak needs addressing.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #469034 3rd Nov 2015 12:59pm
dorsetsmith
1. but you will get low fuel presser to injectors Exclamation
2. Fuel Pressure Regulator also sends unused fuel back too tank
Post #469036 3rd Nov 2015 1:03pm
Disco_Mikey
The copper washer, and external 0-ring
Generally, they dont cause starting issues, unless they are leaking badly. But seeing as you are having issues, its a good place to start
Possibly, but unlikely. Easy enough to test
Very rare, but it does happen...
If it starts OK after priming, then it does point to fuel running back, either from an injector seal or leaky FPR
Thumbs Up
Post #469039 3rd Nov 2015 1:13pm
dorsetsmith
http://www.discovery2.co.uk/Fpr.html
Post #469040 3rd Nov 2015 1:13pm
Freypal
Thanks chaps. By way of a test ill let the pump run for a minute or so tomorrow morning to completely purge it prior to attempting to start. Should eliminate the head/gasket concern.
FPR needs replacing either way so a good place to start. Then injector seals!
Thumbs Up
Post #469052 3rd Nov 2015 2:02pm
