Home > In Car Electronics > Fitting additional fuse box
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Looking into electrics on the 110 for camping etc and adding a fuse panel in the rear to aid fitting etc.
I am looking putting a mega fuse to connect everything to for ease of isolation and then running some 35mm battery cable to the rear (I have these left over from when I use to fit snow ploughs and gritters hence the overkill) I was then looking at installing a fuse box off this in the rear quarter window area something like the blue sea 6 way. From this I can wire work lights etc
Having only done basic kit wireing I was looking for advice on the following
I will have permiment live to the aux box but where and how is the best way to get a switched live to it? Possibly rear light cluster.
Will the fuse box take a 35mm2 cable?
What size cable will be best for wiring initially led work lights to the rear? Amps are so low with LEDs but want to get a reel I can use for other applications down the line.
Any clever ways to get cables in and out would also be useful.
Post #468123 31st Oct 2015 5:32pm
Ignition live would be a better alternative for your turn on method, I'd not use lights in this instance as they are very important.
Have you looked at Bluesea fuse boxes?
Online if you work out the max load you'd ever use ad the fuse box rating you can determine the gauge of cable and fuse needed.
The fuse protects the cable not the device so the cable must be rated higher tan the fuse.
There are calculators for this online inc voltage drop considerations. (N/A in this instance)
I'd run power direct from battery along with a tap from ignition as your turn on method.
There is a power source back there behind the NS speaker panel but A, it's permanent live. (Not a problem if you're using a Relay)
And B. More importantly rated around 20A IIRC.
It maybe suitable for your purpose but depends what you want from it as it will be limited.
Post #468126 31st Oct 2015 5:50pm
mikeh501
The blue sea uses a 110a feed. 16mm iirc. You will have trouble with getting connectors big enough for cable and small enough for fusebox using 35mm
Id buy proper rated cable and fuse box.
Direct connection to battery with isolator or relay from ignition live. Id also send the neg back to the battery too. Rules out dodgy earth's down the line.
Id look into heatshrink, convultued tubing, tubing glands, grommets and electrical grease to do aproper job.
As for route then I'd go out the back of the battery box and onto the top of the chassis rail until you reach rear of tub then come up through tub near light cluster. If you want to cross the gearbox then go forward under bulkhead following existing battery cable then onto other chassis rail and back.
Post #468133 31st Oct 2015 6:15pm
Sphere
Thank you
Was looking st the bluesea boxes shame it won't take the 32 as I have that already. Have plenty of heat shrink grommets etc so hopefully a proper job.
With the blue sea you can fit both ignition switched and permanent I think so will allow all future items.
Post #468188 31st Oct 2015 9:38pm
Cupboard
what are you actually trying to run from it?
custom90steve: if I'm correct in assuming this is for a 2015 Defender, does the 20A feed still exist? I thought it was removed in the 2.2s?
If it is still there, then that would be more than adequate for running some LED lighting.
I don't know what sort of internal rear light covers USWs have, but in my HT it's a bit of bent metal that's got enough space to fit a VSR, a 7Ah battery, some fuses and a power socket. I think you'd get even more space with LED rear lights.
Going back a step, if you want an ignition live in the back and only want to run one heavy to the back, I think you should be able to take an ignition switched feed from the rear wiper:
Post #468204 31st Oct 2015 10:27pm
"custom90steve: if I'm correct in assuming this is for a 2015 Defender, does the 20A feed still exist? I thought it was removed in the 2.2s?
If it is still there, then that would be more than adequate for running some LED lighting. "
Can't confirm, does anyone know or could confirm themselves?
I also agree with following the chassis back from under.
I did this in reverse for my spots but cable in convoluted tubing also.
So extra protection from everything really.
Post #468209 31st Oct 2015 10:50pm
Cupboard
This thread suggests it's basically still there but a bit trickier to get at.
http://www.defender2.net/forum/topic20319.html
still easier than putting a whole new load of wiring in though Smile
Post #468270 1st Nov 2015 10:51am
delete
Post #468271 1st Nov 2015 10:51am
If you did run straight from battery I'd reccomend car audio cable because it's usually OFC with as little voltage drop as possible and highly flexible.so not like trying to bend a stick around corners.
I can highly recommend Autoleads Proflex, various gauge available too. I've got 4 gauge and goes even bigger to 0.
Post #468291 1st Nov 2015 12:18pm
Sphere
Thank you for input I will look at the audio stuff as will have to get some new wire if the bigger stuff will not fit.
It is just some lights to start with but possibly adding some other stuff in the future. Won't get high draw but want to run new wires so I can isolate easy and add a second battery possibly sometime.
Post #468806 2nd Nov 2015 9:47pm
