![]() | Home > Maintenance & Modifications > light guards - help - DONE ! PICS ! |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
Hi
I bought a set of light guards yesterday for my defender ... However I can't understand the fitting instructions ... ![]() ![]() ![]() sorry if it is a stupid question ... ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. Last edited by lrmaniac on 4th Dec 2010 2:17pm. Edited 1 time in total |
Hi Brendan ... Thank you for you patience, but don't understand a thing about what you said !
![]() That bolt on the picture 13 (there's is only one in the box) must be a disposable one ... as that metal plate ... they're used to do what ? What am I supposed to do with those ? And what do I do winth the nut ? If I had plenty I would go for try and error, but don't want to go that way ... Any more hel ? Anyone fitted a set ? Pics maybe ? ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
LRManiac
As Leeds said this is the tool and the steps to put the rivnuts in place. The tool consist in the bolt, the nut and the piece of metal with the hole also you need the spanner and the hex key So following the instruction of leeds you put the rivnut in place, aftre that you must unscrew the bolt, take out the metal piece and then install the guard using the provided bolts to fix it. You can also you can rent/buy a rivnut tool and replace the steps 13 and 14 / 11 and 12. Here some instructions http://www.ridgelineownersclub.com/forums/showthread.php?t=15647 Cheers and good luck Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
.... man, I must be stupid as a door today !! ...
![]() I have to tighten the rivet with it fitted inside the drill I made on the wing, is that it ? But wont he fall on to the inside of the wing ??!! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Lrmaniac,
Dont worry, Yes, you must fit the rivnut attached to the tool inside the drilled hole and make all the operation. The drilled hole should have the diameter of the cilinder of rivnut + 0.1 mm, The flange of the rivnut prevents the falling inside ![]() Click image to enlarge When you use the tool as in the normal popup rivets the lower part will be deformed fiing the rivnut in the panel. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Watch this link, they explain how the proper tools work but it will give you a idea how the rivinuts work too.
Pete. |
Probably best to try it out first.
If you don't have any spare ones to practise with I may well be able to send you some to play with. Drop me a pm if you need some to play with. Whilst technically the drill hole sizes is 0.1 mm larger then the rivnut od i.e. 9.1 mm drill size. Most people do not have access to drill sizes in 0.1mm increments. Drilling it out at 9mm or whatever the od of the rivnut is will be fine. Remember there is no such thing as a stupid question. However there can be silly answers ![]() Better to ask then drop a stupid clanger which might prove expensive. Brendan |
Well, thank you guys ... ! very much !
sorry for this stupid questions ... but all the rivnuts I ever fitted were the "standard" ones that I used on my SIIA ... My problem is that I did not see that flange on the rivnuts ... they all looked like a clilinder ... now that I removed them from the package ( ![]() ![]() But why do I have to tighten that disposable bolt first ? And do I thghten it all the way down ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
Before you tighten it the disposable bolt, the rivnut will look like this: ![]() Once you've tightened it, it should look like this: ![]() Where the sides have crushed it should hold your front panel, and provide a threaded hole for you to bolt the top bracket into. To work out how much to tighten it, it's best to buy a bag of them, and experiment. Hope this makes sense. ![]() 2008 SWB Truck Cab 1952 80" Soft top |
As you tighten a rivnut up with it firmly held against the wing/panel whatever there are sort of three stages of 'tightness'
!) Minimal as any slack is taken up 2) Medium as the rivnut crushes. Takes about 5 full turns. (Have not counted them) 3) Suddenly goes 'hard' Rivnut is firmly on panel. Little point in going further as you could cause damage. Practise first on som scrap metal rather then on a nice new wing. If you want some to practise with give me a shout. Brendan |
Thank you for your answers !
I don't have any spares to practice on ... so I want to be very careful before I try to fit this stuff ... but your (all of you) replies did help a lot ... ![]() ![]() It's been raining a lot here and as I don't have a garage I have to wait till the rain stops to go and fit the guards ... Will post pictures in a few days ... I hope! Thank you! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
LRmaniac,
Don't worry too much, you can buy those rivnuts in any good nuts & bolt store. So, buy 2 or 3 and the make some practice before use it in your Defender. Cheers and we would like to see your photos! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I tried two stores, AKI and Leroy Merlin, and so far got nothing ... I have to go downtown to the "Casa dos Parafusos" ( The Bolt House" ![]() Thank you Eduardo! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
![]() ![]() Allways you found the same store everywere here is calling "Casa del perno" (Bolt house) First, to do not going there to found nothing, call them and ask for a "porca do rebite" (rivet nut in portuguesse) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
