Home > Maintenance & Modifications > A bar fitting kit
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
A bar fitting kit
I've managed to get hold of a non-winch soft a bar without the fitting kit.
After some googling I think the part number for the kit is VUB501800. It's the bar that needs the two plastic covers on the front
This part doesn't seem to be available at the usual suppliers. Hss it be replaced by another or is it just no longer available? Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #466045 24th Oct 2015 8:44am
nitram17
The a bar has been updated ant they no longer have the fitting at the front and there are no plastic covers so i think e bay is your best bet .......try on here as somebody may have some spares ! I would make sure the fitting kit is for the old a bar and not the new version .
Post #466060 24th Oct 2015 9:55am
TDCi Guy
Thanks nitram. Will put a post up in the wanted section. Thumbs Up Tom
@tditomprice
Post #466103 24th Oct 2015 12:33pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Post #466107 24th Oct 2015 12:54pm
TDCi Guy
Nope that's the kit for the newer type without the plastic front covers.
Thanks anyway Andy Thumbs Up Tom
@tditomprice
Post #466112 24th Oct 2015 1:13pm
glpinxit
Somewhere out there is a TD5 90 wearing a soft A-bar (with the pre-2007 front panels) mounted on brackets made by me. I was a bit grumpy to have to after it turned up with out them which wasn't made clear in the eBay advert. It took a bit of imagination as I had no photos or drawings but turned out well in the end. Sorry, I didn't keep drawings - messing about with cereal box card should get you the basics and I used 3mm steel left over from chassis repairs. Cheers, Guy.
Post #467141 27th Oct 2015 11:07pm
