Home > Td5 > Exhaust fumes |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
I'd say so, there is 2 of us (td5 owners) at work and they do 'pollute'.
23rd Oct 2015 7:33am |
I meant it's standard !
23rd Oct 2015 7:35am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5697 |
Yes. Is normal and much worse if cat has been removed.
23rd Oct 2015 7:55am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
No cat on mine (apart from the one that likes to sleep on a warm bonnet)
Its like your eyes are going to start watering! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd Oct 2015 8:07am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Yup. Mine stinks too. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
23rd Oct 2015 9:20am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Mine doesn't smell of fumes at idle.
I'd check all the usual suspects, air filter, MAF & MAP sensor, see if the EGR is stuck or gunked up (if still on) etc. |
23rd Oct 2015 9:59am |
My EGR is blanked off and will clean MAP sensor. Dont have the correct tools to measure the MAF, so will have to check the voltage 1999 Defender TD5 110
23rd Oct 2015 11:11am |
All mine have done this with cat removed. It's makes your eyes water and give you a good cough.
23rd Oct 2015 4:48pm |
It certainly does that ! 1999 Defender TD5 110
23rd Oct 2015 7:52pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2098 |
Eyes watering may be a result of the end of an icon? Mine smells quite a bit too |
24th Oct 2015 6:24am |
