![]() | Home > Puma (Tdci) > Transmission clatter |
Clutch I expect. When you turn the engine off can you hear a couple of metallic "clunks" from the underside of the car just as the engine stops rotating. 130's have feeling's as well you know
toshers Member Since: 19 Sep 2010 Location: Inverurie Posts: 120 ![]() ![]() ![]() |
Is this noise the clutch? Mine has started doing this recently. I've also noticed a similar noise at idle! |
Yep its the little coil springs in the pressure plate. They slacken off and rattle. Warranty fix
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
The other day at the stealer I was able to had a look to the lastest version (2?) and 1 of 4 sets of springs was quite loose. Puma 110" SW
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Thanks all. Not very encouraging though, I'm on my second clutch plate at only 20,000 miles. |
My last one lasted 5k 130's have feeling's as well you know
Ford Puma 110" SW
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
Had all these noises on my 90 31000mls clutch done on warranty.My 200tdi dico did 120000 mls on first clutch,only changed as g/box was taken out.Good old landrover one step forward two backwards. Still best 90 i have driven.
Thanks. Just waiting to see if the dealer comes to the same conclusion. I can do but wish!
