Home > Off Topic > Any Quad or ATV experts on here?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've just sold my old quad, a Kawasaki KLF300b, which I used to pull a topper around and a small trailer around our land in order to save my legs, I'm not getting any younger and I find being able to load up the trailer with hedge trimmings, logs, feed etc a good thing, but I decided to sell it as the clutch was on its way out.
I have used my 90 for pulling the topper but it's not easy to see and feel what's going on behind.
I've looked at something newer - Honda TRX420, Suzuki 250 Ozark or 400 Auto KingQuad, seen a nice Polaris 550 XP EFI locally.
Has anyone got experiences, good or bad of ATV's, and have any recommendations?
Post #464560 19th Oct 2015 8:20am
K9F
Morning Lambley,
Walfy I think is/was a bit of a quad guru?
GoBeyond had one and AJS4X4 has I believe? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #464565 19th Oct 2015 8:35am
I've had several but I'm not an expert Embarassed
Walfy is, as is TJ110 and AJS4x4, also try GB MUD Thumbs Up
Post #464566 19th Oct 2015 8:42am
If you want proper Road Legal then its a Quadzilla as the proper makes Honda Kawa don't do more than Agi Road legal
We use a Quadzilla 800 Twin to lug broken cars around on static bars plus gritting use
I do miss my Quaker 750 Twin thou Big Cry
Post #464572 19th Oct 2015 9:06am
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
We have a Honda 350 fourtrax 4 wheel drive quad. you can't go wrong with Honda. Depending on how much you use it, it may be worth you considering some of the diesel quads that have come on the market in recent years, these can be run on duty free diesel and dependant on use, the fuel saving could be significant. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #464587 19th Oct 2015 9:37am
RobKeay
I thought my clutch was going on our 350 Honda. I then found out it was adjustable.
Post #464621 19th Oct 2015 11:52am
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
I've had a Quadzilla 500es lwb for just over 2 years now.
It has harrowed paddocks, pulled trailers, been used to pull out strainer posts and small tree stumps amongst other things.
I figured for the occasional use it gets, not a daily machine, if it lasts 5-6 years minimum it still works out cheaper than a more expensive machine.
Build quality is OK not fantastic but hey we are Defender owners when have we cared about build quality?
It does everything i need it to do.
I have the lwb and have had passengers on it quite a few times, handy if you need to nip back to get a different tractor or to both head off for lunch/end of day but want to leave the machinery on site.
With hindsight i would have paid a bit more and got the slightly dearer 600 with efi.
Post #464680 19th Oct 2015 2:13pm
TJ101
Had a couple of Yahama Grizzley's.. good quad
But needed a proper road legal quad,, only one real choice, Canam Very Happy
Now on my third, been used for all sorts, from offroading in the Pyrenees, goffer / media on Croatia Trophy, to towing it behind the Motorhome
Would i buy another one,, Yes no question,, none have given any trouble whatsoever, bar me busting the key in Croatia !!
Mine the 800, but doubt you will need one that size
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #464692 19th Oct 2015 3:08pm
Lambley
Thanks for the replies, much appreciated.
I like the Honda's best but they tend to be more £££'s, the Grizzly's look good too and the King Quad, I suppose they are all good these days, so, what cc's would be good to go for, out field isn't flat but gently slopes, but other areas are about 30% slopes, the topper is a Wessex 1.5M cut which is fairly heavy, the 300 Kawasaki was OK - just, but something more powerful would be easier.
Post #464727 19th Oct 2015 6:01pm
Romadog
You sold the best machine for manoeverability, a 2wd Kawasaki.
As one is not getting younger then why not get a Kawasaki Mule 600, 2wd or 4wd?
Easy to get in, good visibility and able to carry stuff without need of a trailer all the time.
http://www.kawasaki.co.uk/en/products/mule...15GDQZFPSM
Post #464728 19th Oct 2015 6:01pm
rory_mcw
Polaris ranger mid size, turf mode, the etx or 570 would be ideal.
Post #464776 19th Oct 2015 7:59pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Have worked with quite a number of types of quads over a few years, if I was spending my own money for a 'work' machine it would be a yamaha grizzly- not quite as pricey as the Honda quads and parts are significantly cheaper.
We ran a pair as instructor bikes in the Highlands for a few years and they were mint had virtually no trouble with them. If your on one all day it's well worth plumping for one with independent suspension at the back too!
My old boss has been using a couple of tgb blade 350cc that he rates very highly- the only criticism is they are massive!
We ran some smaller (250cc I think) polaris bikes on the tour fleet for a while. They were awful. Fell to bits and getting parts was a nightmare.
A side by side atv is a great piece of kit I have used John deere, yamaha and polaris flavours and similar to the quad bike experience the yam and the John deere made the polaris look shoddy, The pair of polaris ones I have used you had to sustain an uncomfortably high speed when descending slopes in order to keep drive engaged for engine braking-most disconcerting!
Side by sides have nearly All the advantages of a quad but are more comfortable and with better weather protection- as well as being able to carry more!
Chris
Post #464813 19th Oct 2015 9:27pm
Lambley
Thanks again.
I did look at a mule, might be an option and handy with the trailer attached.
Chris66 - cheers for the heads up on the grizzly, good to know they they're top of my list. My local dealer is a Suzuki stockist and I get along with him well, he gets the odd used bike in now and then but only sells new Suzuki's.
It's a shame but we only 'need' one every now and then, most of the time it'd be stuck away in the barn, but I like cutting the paddock myself rather than relying on a farmer or contractor, plus just moving cuttings, tools, rubbishy for a bonfire etc, just a few hours here and there is very useful. I'm not fussed about the cosmetics or condition, just that its mechanically sound.
Post #464855 20th Oct 2015 6:54am
Chris86
We used to move 'dead' landrovers about with the 350cc yamaha bikes without any issuejust fetching them in and out of the workshops etc. I also used a military spec grizzly 450 for a few months on a job in Morecambe Bay- it was an absolute animal- so good for dragging stuff about in the sand and mud though!
One of my pals has recently picked up a tidy Yamaha 350 bruin for some of his grounds maintenance jobs for a good price. He tows a small trailer about with that and uses it for moving logs about.
Chris
Post #464985 20th Oct 2015 4:09pm
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
x2 for the Can-Am
Owned 3 in the last 10 years and thoroughly recommend them, in terms of tech and performance they are leagues ahead of their Japanese rivals (or at least were back in 2010 when I bought the last one).
Pic of me competing in the Baja GB back in May
 -2015 Defender 90 XS Landmark-
Post #465032 20th Oct 2015 6:24pm
