![]() | Home > Technical > Headlight adjuster |
Goosed!
![]() They can seize if not used for a while. http://www.defender2.net/forum/topic39745....t+adjuster If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
