Home > Maintenance & Modifications > Fitting New Wheels |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1641 |
Copper slip... a good idea
130 ft lbs I recall is correct. YOLO... You Only Live Once... |
18th Oct 2015 11:53am |
rob369 Member Since: 05 Feb 2014 Location: eastbourne Posts: 17 |
g'day yolo, Thanks for the advice, good luck in the rugby. rob
18th Oct 2015 12:08pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
you will need spacers on if you want to keep the hubcap cover on the boosts
18th Oct 2015 12:43pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
There is some discussion of torques in page 12 of this thread... http://www.defender2.net/forum/topic31672-165.html
MY16 owners book has 170 Nm (125 ft.lb) for 7" alloys... https://topix.landrover.jlrext.com/topix/c...e79!!3!225 |
18th Oct 2015 1:13pm |
Very strange if topics says 170Nm for 7" alloys. I just logged on to topix and on page 114 of the user manual it reads as copied below:
9. With all wheels on the ground and the jack removed, fully tighten the wheel nuts in the sequence indicated above to the correct torque of 133 Nm (98 lb.ft). I think the 170Nm applies to 6.5" HD Wolf wheels only. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
18th Oct 2015 3:00pm |
From the link I posted.......
Click image to enlarge |
18th Oct 2015 3:07pm |
I can well believe you, so two possibilities as topix for my 2009 model still reads 133Nm today....
1. the recommended torque for 7" alloys has increased from the 133Nm for a 2009 model Puma to 170Nm for those that roll out of Solihull now. 2. there is a misprint in the topix for the current model years where someone accidentally used typed the 170Nm for the HD Wolfs also as the number for the alloys. Seems a question for our dear Ryan of Land Rover Customer Relations. His collegues inside should be able to clarify which numbers are correct for each of those wheels and if there are any changes in recommended torque between 2009 and today. Until further notice, I continue to use what is written in my topix for 5" alloys, i.e. 133Nm Ryan, please comment. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
18th Oct 2015 3:19pm |
This is now going off-topic, but as you have asked Ryan to comment - there is a definite error in MY116 manual I noticed recently. The index entry for fuel tank capacity points to page 114. But it clearly isn't on page 114.
Where there is one error...maybe more? Click image to enlarge Click image to enlarge |
18th Oct 2015 3:34pm |
LOL! YOLO... You Only Live Once... |
18th Oct 2015 4:28pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1720 |
He shouldnt do that was only early 90's and 110's not defenders, his will be fine without spacers |
18th Oct 2015 6:05pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2637 |
Actually the 'wide hub' drive members which prevent the fitting of those alloys continued into Defender production. They disappeared when the 300Tdi came in and brought the thinner hubs and drive members.
18th Oct 2015 7:04pm |
Hi everyone, thanks very much for your input, I fitted the wheels to my 2011 defender yesterday torqueing the wheels to about 130 nm. They look great! It even seems to drive better! The only thing I was not sure about was as to whether to remove the small rubber dust cap from the centre of the hub but they seemed to fit over them ok.Cheers Rob
21st Oct 2015 9:49am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
No, the dust cap stays put! Steve.
21st Oct 2015 10:21am |
Thanks Steve, that puts my mind at rest.Rob
21st Oct 2015 10:32am |
