![]() | Home > Puma (Tdci) > My first warning light, is this my welcome to ownership :) |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Just needs reading on Diagnostics.
Don't worry too much, as they can throw a wobbly sometimes and mean nothing! I would buy a cheap code reader so you can check yourself, rather than paying a garage to do it for you. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
If you start and fully restart the engine 6-10 times it will reset. if your 2.4 hasn't had an EGR replaced it may be an early sign of an imminent failure. I just had mine changed at 36,000 miles and the old one degraded so slowly i forgot how good it should run. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3795 ![]() ![]() |
^ That sounds promising, the start and stop routine. Although I wonder why it came on?
Mine on 62K no idea if that valve has been changed or not, any idea on cost? Its got a After Market warranty so do I take it in now, or just stop start and hope it resets? Thanks |
At that mileage it has probably had at least one and possibly a clean and refit. A hard reset (+ve cable off) would probably put the EML out if the stop/start doesn't.
Your engine will run much sweeter with a new one. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
How much are they?
I've not driven another so cannot compare it with one, it seems to drive fine to be honest? Coming from a normal automatic car its more my poor gear change etc that makes the ride fun ![]() I'm getting used to that though ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Is it still on, or did it come on and go off?
I will walk over to it in the carpark at lunch,
When it came on it stayed on. I did turn it off when here and then on in the 'hope' it would go out... But it didn't Will see if its on when I go out soon, |
From a couple of old thread about 'nuisance codes.'
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 15th Oct 2015 11:14am. Edited 1 time in total |
Still on and I started / stopped the car and moved forward and back half a dozen times in a hope it would go off..
Did you stop/start from key position "0" to start many times? Just flicking back and forward will not reset EML. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
About 6 times key out to engine on
Light still on |
It may reset after a few driving cycles. Invest in a Fault Code Reader and/or call Land Rover assist if you are under warranty? If not the reader will pay for itself first time you use it in a situation such as this. If you go through life with your head in the sand....all people will see is an ar5e!!
What reader do I need and where does it plug in.
Are they easy to use? |
Do a search using keywords such as Ultragauge, Scangauge, Fault code reader. It plugs in to the OBDII socket under the panel below the steering wheel by your right knee and will give you real time readouts of several parameters not shown on the dashboard and the ability to read and clear fault codes. Very easy to use. Please do not ask what an OBDII socket is.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
