Home > Maintenance & Modifications > 110 CHEVY CONVERSION? |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3781 |
TOP idea, but if ya can't do it yourself, and have to pay to get it done, ya'd wanna have deep pockets.
"420" small block, ...never heard of that one, ..what is it, could it have another name,...LS1, LS2, LS3 etc? Are you going for an "early" engine or one of the later "LS" Series. Far better way for all the trouble & expense you'll have to go to,....I'd recommend the LS3. Pickles. |
14th Oct 2015 8:52pm |
andygsi Member Since: 14 Oct 2015 Location: GUILDFORD Posts: 3 |
Thanks for your feed back. I have seen a chevy v8 small block 420hp on net and am wondering if this would fit in a 110. Weather I can do the work myself is to be found out. Lol. Welding is not a strong point but good at most other things that don,t require laptops. The plan if I can call it that is to have a big engine and nos! Obviously this would be an ongoing project! What is the ls3 you speak of?
14th Oct 2015 9:15pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Yes its sounds a good idea,
yes it con be done, You will need to uprate your diff's, shafts and cv's for that sort of power. |
15th Oct 2015 10:28am |
The LS3 is a GM LS Series engine, one of the last, & actually, & funnily enough it may be the engine you speak of, because it's output is around 300KW, but there are various + or - states of tune. An absolute ripper engine, good power & plenty of torque,...a nice lazy modern V8 with plenty in it for more if ya want "more".
But the actual engine will be the least of your worries. These engines are "electronic" so ya'll have to work out that side of things, ECU etc, to just get the engine to run!! But if ya're gonna do something like this, then an LS3 would be as good as anything,....IMHO anyway. Pickles. |
15th Oct 2015 10:44am |
Redlinemike Member Since: 27 Oct 2013 Location: Frozen north, Just off the M8 Posts: 100 |
im looking to do a similar thing but using a LY6 & a 6l90E, LY6 is the cast iron 6.0L "truck" version of the LSX enging family<
with little tuning & a resonable exhaust & UK pump fuel, expecting a smidge over 400bhp at the flywheel 110 XS DC M57 + 8 Speed auto ORA jeep- Sold Tomcat 88 |
16th Oct 2015 6:14am |
WHERE IS THE BEST PLACE TO GET THE EXTRAS IE DIFF.CV.PROPS ETC???
17th Oct 2015 7:23am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1308 |
Seems like you need a new keyboard too as your current one seems to be stuck in caps lock mode
Edit: just noticed that it is an intermittent issue - worth keeping an eye on it though |
17th Oct 2015 8:35am |
i have nissan patrol axles so in stock form they should be ok, they are considerably more substantial than uprated landrover axles 110 XS DC M57 + 8 Speed auto ORA jeep- Sold Tomcat 88 |
17th Oct 2015 8:51am |
