Home > Puma (Tdci) > Washer nozzles! |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
Bloody things!
Guess they're the first bit to fall off my new 110...probably not the last. One on the front fell off this morning, and pinged down the road. Checked the one on the rear and it came away in my hand. My LR dealers is on my way to work, and strangely enough, they had 'dozens' of the the things in stock...! I'm thinking they are a frequently lost bit. Got the new bit but can't work out how to a) remove the outer nozzle bit from the rest (comes with the rest of the part as well) and b) keep it retained on the bit sticking out below the windscreen. Any tips? 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
25th Nov 2010 12:32pm |
Cheers!
Will give it a go. 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
25th Nov 2010 3:16pm |
entreq (site sponsor) have a project to re-design these ... another top seller if they make it !
25th Nov 2010 6:20pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
use screen wash addative,that will stop the water freezing in the lines and pushing the nozzles off 2.4 90 XS
25th Nov 2010 8:12pm |
but it is for headlamps cleaning, not for windscreen..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Nov 2010 7:29am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
What he said...no problem Mike |
26th Nov 2010 4:02pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
SWRA WINDSCREEN WIPER CLEANER DESCRIPTION Our windscreen wiper cleaner ought to have been ready long since, but there were a number of minor problems. First, the standard water tank for the windscreen jet nozzles is far too small for the entire SWRA system to work satisfactorily. Then there were repeated malfunctions of the hold pressure value until we finally found the right manufacturer. To crown it all, the high-pressure pumps had difficulty in taking up water from the (refilled) reservoir because they are always designed for fitting directly in the water container and not for external use. We are now working on an additional tank for the SWRA with a volume of just under 10 litres of water because it is only then that a cleaner with high water consumption really makes sense. Last edited by Lorryman100 on 26th Nov 2010 4:55pm. Edited 1 time in total |
26th Nov 2010 4:49pm |
Mike
26th Nov 2010 4:50pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4721 |
My washer nozzle on the rear of the tdi got broken some years ago. As a temporary repair I used a piece of break line bent to shape, with the exit end flattened with a pliers. I just stuck it into the protruding plastic pipe over the rear window. This temporary repair is still in place. Works really well. 1982 88" 2.25 diesel
26th Nov 2010 5:24pm |
OK, so following suggestions on here, I successfully separated washer nozzle from the part it fits to, then after heating it up in hot water and giving it a sharp tap with a hammer, got it to click on to the bit sticking out of the scuttle.
Now, being REALLY stupid, I can't seem to adjust the nozzle direction. They both shoot into space! Been trying with a pin, but to no avail. Is there a trick to it? 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
30th Nov 2010 11:30am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I use a needle but i guarantee it will pop off in the minus weather we are having.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
30th Nov 2010 11:32am |
It shouldnt pop off Trick - more antifreeze! Dry jet arm Dab of superglue if it keeps coming off (dab as you want to remove it again!!) Heat and refit Mike |
30th Nov 2010 3:53pm |
Mine did when jets froze and water pressure launched the unit skywards... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
30th Nov 2010 4:01pm |
-10 here on saturday night/sunday and when we left the house at 9 it didnt Mike
30th Nov 2010 4:03pm |
