Home > Maintenance & Modifications > Puma handbrake clicks. (Detail) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
Above quote is from the WSM for the 2.4 Puma. Adjustment procedure is as follows (same source):
That being said, I tend to run mine at 5 clicks to avoid the grabbing/banging that can otherwise occur. |
14th Oct 2015 9:12am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Hi BW,
Yes, that's the thing as to why I think I'll leave it alone. If I know Landy's the more you fiddle unessisarily the more likely you'll cause a bigger issue than when it started. It's parked at home on level ground which is good and helps though, annoying for others that maybe have no other choice though. |
14th Oct 2015 10:14am |
I thought I posted this last night but obviously not!
Mine sometimes holds at 3 clicks, sometimes 4. If you do it 3 it can then roll a bit until it gets to a bit where it holds. |
14th Oct 2015 11:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
You did, in the first one of these http://www.defender2.net/forum/topic40822.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
14th Oct 2015 11:56am |
