Home > Puma (Tdci) > Taking the EGR valve out - hassle or easy job?
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Dear forumites,
I got a new Defender, finally. The price was decent and it's got a well kept chassis and rear crossmember, all waxoyled to the brink, so it should serve me many more years.
Yet, there are some things that need to be fixed. First, I get the MIL light with error code P0404. The EGR valve is stuck, as I can tell when I turn off the car and there's none of the usual chukka-chukka symphony. Not surprising, as the previous owner hardly drove long distances. It's probably all covered in soot.
So I'd like to take the EGR out and either replace it with a new one or clean it. Mechanically, I am a novice, so I wonder whether it's worth the hassle. Has anyone done that before?
How long did it take you, how easy was the job? Or should I rather abstain?
Post #462625 12th Oct 2015 5:11pm
You'll have to do it as tad MIL is an MOT failiure.
It's not too bad but time consuming and a pain in the ass.
You'll need a torque wrench for the torque settings and the manual / sheet with the details on.
Yes, some don't tighten to the torque setting but if you snap a bolt due to over tightening it will be a major pain.
3x bolts accessable from above.
1x best from below but not easy if your very short in the arm
Post #462632 12th Oct 2015 5:24pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Having done several EGRs on Defenders, and Transits, I find it much easier to remove the inlet manifold to do the job.
The extra half hour it puts on the job makes up for the time spent trying to get at everything!
Especially with the 8mm bolts that have a nasty habit of snapping.
I done one last week and knew it was going to break, so I took the whole lot out in one. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #462636 12th Oct 2015 5:32pm
enfield_dinosaur
Ok, got all three - a torque wrench, the workshop manual, and a rather long arm. I also presume that even the mechanical inadept will be able to fit and remove four bolts.
So I assume it's that lower bolt that makes it difficult?
Would you clean the EGR valve or not bother and fit a new one?
Post #462637 12th Oct 2015 5:32pm
ian series 1
 80" 80" 86" 88" 90"
Post #462638 12th Oct 2015 5:35pm
ian series 1
Fit a new one, they are not worth messing about with Wink 80" 80" 86" 88" 90"
Post #462639 12th Oct 2015 5:37pm
enfield_dinosaur
Thanks for the pictures!
Last picture is the open manifold?
ian, by any chance, would you know the part number of the EGR valve in a Puma?
I presume it's this part here: http://www.ebay.com/itm/LAND-ROVER-DEFENDE...0583478894
Reasonably priced, actually...
Post #462641 12th Oct 2015 5:39pm
ian series 1
Hi
Couldn't tell you the number off the top of my head?
Yes, the last picture is with inlet manifold removed, ( makes removal and fitting much easier) they are only held on with 8x 10mm nuts.
New inlet gaskets from Ford are about £16 for 8.
You CAN NOT buy the round gasket on its own, this has to be brought with a manifold, so save it if your going to take it off.
Thumbs Up 80" 80" 86" 88" 90"
Post #462645 12th Oct 2015 5:49pm
enfield_dinosaur
Perfect! I think I'll do the manifold as well and give it a good clean... Thumbs Up
And pray I get it all back together. I work in documentary films, so documenting what I take off where should come quite natural Razz
Post #462647 12th Oct 2015 5:53pm
ian series 1
You will be amazed at the crud you will get out of the manifold!
It's a dirty job, but worth doing.
Just to let you know, the photos are of a Transit set up, but almost identical to a Defender, also I took out the pipe work with the EGR. You probably won't need to do that?
I had to, as the bolt was going to break, so I had to heat it up with the gas.
I just put them up to give you a rough idea.
Post #462649 12th Oct 2015 6:03pm
enfield_dinosaur
It'll be a bit of a dare, but I can see the EGR valve when I open the bonnet and I understand what goes where. I got all the tools and the documentation.
So I'll do my best snake person impression and undo the bolts, clean the manifold, put everything back in - and if I can't get it back together, I got a very skilled neighbour (who built his own BMW E34 from parts) who's gonna get me out of trouble Laughing
Post #462650 12th Oct 2015 6:09pm
ian series 1
I'm sure you'll be fine!
It's a straight forward job, just the location that makes it harder.
Post #462651 12th Oct 2015 6:12pm
Thought those photos looked different, EGR is much the same but pipe work not so. Makes sense you mention it's a Transit.
Yes, I agree change over don't fiddle - not worth it.
Purchasing wise I'd 'PM' Dan @ Duckworth parts here and ask for a prices. Probably likely the best out there.
I changed mine in the past but it wasn't a year and a half before the new one played up just before MOT time!
Given the price and the pain in changing over yourself or paying for someone to do it the cost mounts up.
Even if you do it yourself.
In the long run I'd recommend getting a remap with EGR shut.
A couple of EGR's and you are nearly up to the cost of a remap and remaps have other benefits on top too.
Alice stage 1 for me.
After that, slip a blank in and no more issues permanently.
Post #462665 12th Oct 2015 6:55pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Alive remap + EGR shut for me too. Thumbs Up Thumbs Up Thumbs Up
Very Happy Very Happy Very Happy
Post #462679 12th Oct 2015 7:10pm
enfield_dinosaur
So, all the parts are here! I hope!
Sorry if this is an idiot's question - it probably is, but bear with me.
This is what my replacement part looks like, Part No. LR006650. It's brand new, was a donation...
And this is the part I presumed to be the EGR - with the plug and all, sitting in front of the manifold -
These are not the same Mr. Green
So, do I have the wrong spare or am I about to remove the wrong innards of my Defender?
All advice very gratefully received and highly appreciated! Whistle
Post #464041 17th Oct 2015 12:55pm
