Home > Maintenance & Modifications > A weekend well spent? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2245 |
Beware the Dinitrol police are watching ...
12th Oct 2015 3:14am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
It will either work or not Mike
12th Oct 2015 2:59pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello mse
I have used both: Waxoyl 1275 GT Mini / TVR Taimar / 300tdi Defender SWB Dinitrol 2.4tdci Defender 90 My observations would be: 1. Both are good. 2. Quality of Preparation and Application will determine their success. 3. I would not 'mix' the Products, generally as this stuff sticks to itself best. 4. Dinitrol was easy to work with, but the difference overall is probably marginal. 5. Appearance of Black Dinitrol (4941) is really good when applied. 6. If I do this again (on a new vehicle) currently it will be Dinitrol. 7. When the 90 gets more, it will be Dinitrol. Waxoyl Vs Dinitrol analogy PC Vs Mac...your either one side or the other, but both are very capable. There are some super tough plastic / synthetic coatings out there that are generally out of reach of a DIYer or even Specialist Independent both by price and the methods of application needed to apply them correctly. With a move towards Aluminium and Composites for vehicle manufacture (even rumored for the replacement Defender) what we are doing for Steel is a necessary step to preserve it but one that may well be designed out...eventually. SKIP https://www.defender2.net/forum/topic83242.html Last edited by X4SKP on 12th Oct 2015 7:09pm. Edited 1 time in total |
12th Oct 2015 4:45pm |
X4SKP I had my Defender originally done with Waxoyl since then I have topped up and treated where necessary with Dinitrol. Both are very good products in their own right and I agree wholeheartedly with your reasoning and points above. Waxoyl can be a messy affair and a ba5t4rd to work with in lower temperatures unless you can pinch a baking tray from SWMBO to stick some Waxoyl in to warm in the oven or have a wood burner on which you can warm the stuff on in the tin. Dependent on outside temperature your window of opportunity to get the stuff applied before it turns to chewing gum can be small indeed.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Oct 2015 4:57pm |
Thanks Guys - its reassured me
I leave it in the airing cupboard to warm...always works well, except it was a pig when starting to cool on Saturday (not a warm day) Going drinitol for the last few bits purely because ive run out of all waxoyl now and the drinitol aerosol seems like it might be easier to get in the top of the bulkhead and doors without getting out the compressor cleaning etc Im never too bothered about appearance underneath although it looks fine - probably a brand new chassis helped with that one. Just the axles left underneath to do Mike |
12th Oct 2015 5:14pm |
