Home > Puma (Tdci) > Occasional air release noise when slowing down |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
How long does the noise last for, a fraction of a second or longer?
Two initial guesses, the turbo dump valve venting off any boost when you lift off the throttle or squeeky brakes. |
11th Oct 2015 3:22pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Hi Andy,
It's only a fraction of a second and I'm pretty sure it's not the brakes unless I have a leak with the servo. The dump valve on the turbo sounds more likely- where about is it located and how is it supposed to function? It's not something I had before over the four years I've had he truck. Mark |
11th Oct 2015 3:28pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
No dump valve on the TDCi - when fitted it is to petrol turbocharged engines to reduce overboost / compressor stall when the throttle is closed. (Diesel engines do not use a throttle valve for controlling engine speed)
The noise you are hearing could be one of several things, EGR valve starting to die, Air leak in the inlet system - check the hoses and jubilee clips. |
12th Oct 2015 7:40am |
