Home > For Sale & Wanted > [FOUND] R380 gearbox for 300tdi Defender or remote housing |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
I have an r380 box in which the bearings have gone. It's is complete with bell housing. I'll have to check if I have the linkage for transfer box though.
Let me know if it any good for you |
8th Oct 2015 6:56pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
That sounds good thank you.
The remote housing where the gear levers fit is the most important bit really so definitely interested. Sorry just to clarify it's out of 300tdi defender? |
8th Oct 2015 7:08pm |
Oh sorry my mistake
The box I have is out a td5 Shame that as I just went digging in the garage and found the gear stick linkage Sorry bud |
8th Oct 2015 7:11pm |
No worries, thanks for having a look!
I will just check that the housing aren't the same though, would be good if they were. |
8th Oct 2015 7:14pm |
After a very quick check it would seem the top of the box (the gearstick housing) are the same, so still interested!
Would taking a photo be too much trouble, don't want to inconvenience you. Thanks |
8th Oct 2015 7:39pm |
Ok no probs :thumbsup
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Sorry if they are not the correct way around |
8th Oct 2015 7:54pm |
Wow, many thanks for the quick reply.
Looks to be the right thing indeed, basically the top of the box as in photo 2 Would you be willing to sell that part separately, it could be boxed and posted, if not I'd have to come and collect the whole box!! Cheers 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
8th Oct 2015 8:12pm |
No problem at all to box and post,
Not sure what it's worth to be honest ?? How does £30 plus postage sound? |
8th Oct 2015 8:40pm |
Sounds good to me, many many thanks!!
I'll PM you. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
8th Oct 2015 8:49pm |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
Db950 it is no good you just buying the rear shifter housing to convert a R380 disco box to R380 defender spec, you also need the shifter rail from the disco box which requires a gearbox strip down.
9th Oct 2015 3:16am |
Ashcrofts do an extender and yoke for the rail that can be fitted without stripping the box, so doing that instead of fitting a complete new rail!
9th Oct 2015 4:52am |
I didn't know that they had done that kit.
I used to swap the shifter rails, I devised a way of swapping them in 1/2hr without major dismantling, but ashcrofts used to say it couldn't be done! |
9th Oct 2015 7:59am |
Sounds like you had it down to a fine art!!
I've seen people extend the rail themselves but to save time and hassle I thought I'd just buy one already made. |
9th Oct 2015 8:16am |
