Home > Puma (Tdci) > Hesitation/P2263-22 and P00BC-00 on Puma 2.2 with DPF |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
This to me points to a sticky turbo actuator link. I've never had this problem myself but read many threads about it. There is a way of disconnecting the link and freeing up the linkage but I'm unsure how to do this. Hopefully someone will be along shortly with some more help.
8th Oct 2015 8:28am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Happens to me something similar (randomly loss of power) and happens to be the MAF that was not reading correctly.
Can you read the MAF values? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
8th Oct 2015 2:47pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
If only on long hard drags where the car is working make sure its not temperature related because you can get a similar fault when the turbo actuator gets to hot and the motor starts to stick or the vgt mech sticks, it can then draw to much current and the ecu assumes a circuit fault.
I assume you are still standard exhaust system ? Pete. |
8th Oct 2015 3:52pm |
