![]() | Home > In Car Electronics > 08 Puma Stereo Wiring Query |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
Sounds like it's not got permanent power.
When ignition off, it should have a nominal power draw enough to keep the settings but not drain battery. Sounds like it's completely off when ignition off and on when ignition on. Are you sure the wiring hasn't been altered? Most ISO wiring will not need any changing at all. All the same yellow is ignition and red permanent live. By the rounds of it you need to swap these over. |
KeswickKeeper Member Since: 07 Oct 2015 Location: UK Posts: 8 ![]() |
Yes that was it all sorted thanks for the info I appreciate it.
