Home > Puma (Tdci) > Interior lights not working
Littledave12
When I unlock the vehicle with the remote the interior lights flash once then stay off, even when I open the doors the lights still don't work. Both lights work manually.
Any one got any ideas???
Thanks Dave
Post #461145 6th Oct 2015 9:52pm
When you say they flash do you mean in sync with indicators on unlock?
Post #461150 6th Oct 2015 10:13pm
Littledave12
No the interior lights flash once and only lasting about one second, the indicators do what they always have and stay on for about 4 seconds.
Post #461222 7th Oct 2015 8:51am
K9F
Each of your internal lamps have a white/purple wire attached, disconnect this and check it to earth whilst opening each door in turn, each one of your door switches when the door is opened gives the circuit an earth to activate the light through each switch fixings. On the face of it it looks like this common earth may be missing/open circuit. When activating/switching the light itself on it uses a different earth and that is why it works. Good luck. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #461226 7th Oct 2015 9:02am
Cupboard
the lights have 12V permanent, 0V permanent and a switched 0V from the 10AS which is the unit that controls the alarm and central locking. The 12V feed is always attached to one side of the lamp, and the switch selects whether the other side is connected to nothing (off), the 0V feed (on) or the 10AS (auto). The 10AS controls the dimming and everything through some sort of solid state drive (transistor or something).
Given that the manual works, we can assume that the 12V and 0V feeds are fine. If the lights consistently flash every time you try to unlock, but never do any more than that I'd be suspecting the 10AS has some sort of overload detection that's tripping.
Have you tried to see what happens with one one of the lights on auto? I don't know what sort of Defender you've got so you might have to try it with each in turn.
Post #461284 7th Oct 2015 12:47pm
RED-DOT
I had wonky interiors too and it turned out to be water getting in to the multi plug near the top of the windscreen. Roof lining out and the rot was easy to see. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #461329 7th Oct 2015 3:59pm
Overload or underload could be a problem.
Are there bulbs fitted or LED's fitted?
Post #461373 7th Oct 2015 6:37pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I may have the same problem, the rear door light used to stay on for like 2-3 minutes at least when I open the rear door, now, it dimms immediately as I open the rear door.
Post #461452 8th Oct 2015 2:28am
Cupboard
My 110 HT with a single LED interior light doesn't seem to suffer from underload issues Smile
Post #461552 8th Oct 2015 11:51am
Littledave12
Just an update for everyone, after checking the wiring and not being able to find any faults I got a friend to plug there auto logic in and found out somehow the interior lights had been switched off in the alarm ecu. Now switched back on they are all working as they should. Thanks for everyone's help
Post #461928 9th Oct 2015 8:12pm
Very odd that unless it was done by accident. Have you had any electrical issues sorted lately?
Post #461952 9th Oct 2015 9:22pm
Littledave12
No nothing, parked it up Monday night and all was working as it should then Tuesday morning no interior lights.
Post #461989 10th Oct 2015 6:17am
barbel jim
Mine have started playing up today ! Yes it been wet again, but mine do the opposite, they stay on permanently. Get the horn beep when I go to lock and they still stay on. Only way to turn off is on the fitting itself. Dealer can't look at it till the 15 th February Rolling Eyes thanks for your £30 grand see ya Ner Ner only 5 months and old !!!
Any ideas ???
Post #495183 22nd Jan 2016 2:27pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Curious, Isn't the horn sound when a door is not closed when you arm the alarm?
Post #495193 22nd Jan 2016 2:58pm
barbel jim
Yes but I believe the alarm/interior lights/ central locking are all linked. It's back to normal now, but I'm thinking it could be a water ingress issue, similar to what Red Dot had
Post #495209 22nd Jan 2016 3:51pm
