Home > My Defender > Double cab |
fantic Member Since: 29 Sep 2015 Location: Midlands UK Posts: 10 |
Recent new wheels
Click image to enlarge |
29th Sep 2015 8:31pm |
29th Sep 2015 8:40pm |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 |
V-nice landy
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
love it i want it ....... fancy a vintage 90
30th Sep 2015 4:16pm |
Challengers at a glance as the spokes seem not quite uniform, but it could be the light/filter. If you go through life with your head in the sand....all people will see is an ar5e!!
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 30th Sep 2015 4:21pm. Edited 1 time in total |
30th Sep 2015 4:17pm |
jk84 Member Since: 17 Feb 2015 Location: Wherever my Defender takes me... Posts: 720 |
Really nice truck! I see optimil side vents, well done But wonder what kind of top vent you have - I can see a bit from the picture but not anough. Another detailed picture perhaps.
30th Sep 2015 4:19pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Nice, is it lowered?
30th Sep 2015 4:51pm |
Thanks for the positive posts.
The Wheels are 16" x 7" Challenger alloys with 10mm positive offset, to put the wheel slightly further into the arch. (different spec to challenger steels) The tyres are the new BF Goodrich all terrain" 285 wide x 75 x 16. KO2 The tyres do not protrude past the arches at the top, but at the side, you do get spray on the vehicles sides, in the wet. These tyres are almost 33 inches in diameter, therefore just over an inch bigger than standard Defender tyres. But I think that inch just fills the arches out, to give a better look!!!!!!! My opinion only. The vehicle is lowered 2 inches at the back and 1" at the front..........Making the vehicle level, rather than the standard pick up with a raised back end. Tyres and wheels are from 4x4tyres.co.uk Spring kit is from Frog Island 4x4 part number TF035 Click image to enlarge |
30th Sep 2015 6:25pm |
The air intake vents are from Bolt on Bits, available on ebay. They look okay from a distance!!!!!!!!!!
http://www.ebay.co.uk/itm/RDX-Wing-Top-Ven...540514e602 |
30th Sep 2015 6:36pm |
