Home > Td5 > Rear Window Heater |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Probably one or more elements on the glass has worn away, or broke?
The high level brake light cover can rub through. Try testing at the contacts on the window with a multimeter to find the break. You can get heated screen repair paint to fill in the gap. Quite a common problem on the Defender I'm afraid. Sorry, just noticed, you have no power! Try looking or testing wires where they pass through the loom from body to door. You may have a broken wire somewhere? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
21st Sep 2015 5:52am |
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 |
Mine same...William's stated MOT failure so I hard wired to black cable used rubber seal glass for cable support works well.
21st Sep 2015 6:15am |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
I have only one element working on mine. Are new screens available? From my series experience I know swapping the glass is easy but does the high level brake light come off? 1999 Td5 110 CSW 1961 Series 2 88 LPG |
29th Sep 2015 8:24pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Check the wiring inside the flexible rubber which leads from the rear body to the door. Often fatigue and snap. 02' 110 TD5 Double Cab Rebuild Thread
29th Sep 2015 8:52pm |
Simali Member Since: 25 Jun 2015 Location: Basingstoke Posts: 46 |
Ta Steve turned out to be a broken cable in the rubber tube
25th Oct 2015 10:57pm |
