Home > Puma (Tdci) > Electrical gremlin?
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Electrical gremlin?
Hi
Over the last few weeks I have had a few electrical issues with the Puma.
First, the ABS, TC, Brake warning light flickers on/off at random, I've plugged it in to my Modus and no faults were showing?
So I've ruled out the abs modulator/wheel sensors as this would have logged a fault.
I've also noticed the rear wiper no longer works, only intermitantly.
Locking the car the other night, I then noticed that the 2 rear RDX indicators only light at the bottom, not showing a full set of LEDs?
Again this seems to be intermittent!
I'm now guessing an earth problem/ loom rub through somewhere on the rear?
I can't really check until the weekend now.
Does anyone know if there is a weak part of the loom that's common for failure on the rear of the Puma?
I will try to look at the earth points later on the transfer box.
Cheers 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #458876 29th Sep 2015 6:00am
K9F
I would treat each and every problem and tackle them individually.
The 'three amigo ABS lights' I also had a long running issue with and it transpired to be a chafed loom where it was routed and rubbing over the rear axle. I used a multimeter and checked for resistance values and for short circuit of each sensor from under the seat. Each sensor should give a value of approximately 1000 ohms.
This is the chafed sensor cable I discovered.....
http://www.defender2.net/forum/topic2394.html?highlight=ohms
The intermittent wiper is most likely to be a broken cable in the rear door rubber umbilical. Take the door card off and check for voltage, identify the cable and try to gently pull it out of the umbilical.
Indicators, if you still have the original incandescent ones fit them and try them. Do the RDX ones work with the hazard warning switch ok? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458889 29th Sep 2015 7:27am
ian series 1
Cheers Mal.
I can back probe the ABS cables on Diagnostics to get a read out of values, so that's straight forward.
I'm sure it's a short somewhere, as when I pulled up at work I tried the indicators, they worked fine.
Also rear wiper was behaving!
Interesting to see the picture of your cables.
I will try to get out before it's dark, and have a quick look to see if mine are the same! 80" 80" 86" 88" 90"
Post #458894 29th Sep 2015 7:52am
K9F
No worries. My fault too was intermittent over a period of months and got worse in damp conditions. Each time it went to the dealers the fault would not manifest itself. I could only address it once it degraded into a permanent fault and I had to pull the main ABS fuse to make it driveable. Having had the Defender waxoyled it was very difficult to find exactly where the cable was damaged. I had to crawl underneath with a can of WD40 and plently of rags and wipe the cables down before I eventually felt the damage. As an electrical engineer if memory serves it took me about 8-10 hours to diagnose and fix. Very satisfying when you consider how much it may have cost me in a dealership. Mind you they probably would have just thrown parts at it (new rear loom, sensors etc.) until it was resolved?
Good luck! Hope you get a quick and easy resolution. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458896 29th Sep 2015 8:01am
ian series 1
Quick update on this, as if you do a search many posts always start with the problem, but then the op never comes back to give the final answer!
After What seems a hell of a lot of probing, poking, stripping, testing I have found the culprit.
I checked the earths on the gearbox, nuts all tight, everything seemed fine?
So my attention turned to the rear loom/trailer plug, rear lights, wiper motor, still no faults?
This turned in to a major headache, back probing ABS sensors time and time again, stripping just about everything I could think of?
It manifested itself to be one of the ring terminals on the earth point on the right hand side of the transfer box.
It had broken, and was held together by the insulation!
This must have happened when I replaced the clutch a few weeks ago, probably tightening the nut?
It's taken a few days of head scratching, swearing, and general confusion, Big Cry
I now have working lights/indicators, and No ABS/TC lights
Hooorrrrraaaaaaa. Thumbs Up 80" 80" 86" 88" 90"
Post #461628 8th Oct 2015 6:24pm
K9F
Thanks for the update. Thumbs Up
Fantastic result and undoubtedly extremely satisfying you found it yourself. Well done! Bow down Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #461723 9th Oct 2015 12:57am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
If you read the 1st post and then the last, you realise that you could have linked the issue to the time you had the box out and then would have started with the wires round that and would have found it immediately.
Hindsight is marvellous isn't it.
Post #462101 10th Oct 2015 5:21pm
ian series 1
Mmmmm.........
Not really, I had done the clutch quite a while before this happened, and have covered many miles since then,
The first problem I had was ABS/TC light on, everything else worked.
Only in the last couple of weeks the rear lights become an issue.
The way this manifested itself I believed it to be a genuine ABS fault.
Even then, I checked all earth points, connections around the gearbox, and everything I had disturbed, everything was good and tight.
Only when I had time to run diagnostics did it lead me away from modulator/sensor fault.
Took a while to find.
Got there in the end though Thumbs Up 80" 80" 86" 88" 90"
Post #462128 10th Oct 2015 6:36pm
