Home > Maintenance & Modifications > trim clips - part number
ericvv
Can someone post the part number or a Britpart website link, or link from other supplier to these two types of rear panel plastic trip clips? I guess we can order them from Britpart, but I am getting lost on their website as one of these two I can just not find on there.
Thanks, Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #458402 27th Sep 2015 12:43pm
Romadog
Post #458420 27th Sep 2015 2:29pm
ericvv
Thanks Romadog. Those EYQ100130 I had already found on Brit-car website. Those in my SVX are the two you see at the left bottom in my picture. But the screw and plug going into the vertical panel, so the one you see at the right in my picture is in my case a totally different model. That is the one I could not find back on the Brit-car website, I have scanned all their black plastic trip clip range, but with no joy. This one has a larger diameter plastic plug than the EYQ1001330, and the screw is a different model too, longer, also plastic, but the shape of a real screw. Ideas?
Post #458423 27th Sep 2015 3:02pm
Romadog
Had noticed, but hoped it was an easy fix as I couldnt see the other one either.
I've looked at LRCat as well.
Suggest you go to your dealer and ask them to get the correct part number.
Post #458432 27th Sep 2015 3:46pm
ericvv
Post #458440 27th Sep 2015 4:37pm
Martin
Site Admin
I think EYQ100130 is correct, they should all be the same. The LR parts catalogue only shows EYQ100130 and no other clip.
Perhaps your two on the horizontal edge have been changed for non original ones at some point?
Don't forget Dan at Duckworth can supply at a discount compared to Britcar which is full retail price.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #458718 28th Sep 2015 4:27pm
ericvv
Martin, thanks for that. But in my SVX, there are two different types from new as per the picture in that panel. Why am I not really surprised by Land Rover's engineering and assemby surprises? Laughing
Eric
PS - I typed EYQ100130 into the Duckworth parts search engine and came up with nothing. You never actually own a Defender. You merely look after it for the next generation.
Post #458730 28th Sep 2015 4:47pm
Martin
Site Admin
PM Dan - duckworthparts - their web site does not list every single LR part number.
Even in the SVX section of the parts cat it only shows EYQ100130, sorry Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #458731 28th Sep 2015 4:49pm
ericvv
Post #458737 28th Sep 2015 5:01pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #458792 28th Sep 2015 7:13pm
