Home > Technical > Starting problem
90def
2011 Defender 90 Puma 2.4 HT Epsom Green
Starting problem
I've got a 60 plate 90 .when I start it it just cuts out .. And there is no thotle on the second time of starting it is the same ... But on the third time it starts with a rattle then clears and is fine its done cold and after a run.. Any ideas cheers Phil
Post #458302 27th Sep 2015 7:11am
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
First port of call is get the fault codes checked. Could be the vcv valve that's Censored but clutching at straws without knowing what codes are stored
Post #458365 27th Sep 2015 11:01am
