Home > Td5 > fuel pump noise
foxing
Wales
fuel pump noise
my fuel pump has started to make a noise when i turn the ignition on,i don't think the pump is on it's way out as the pump is only about three months old,I've put a link to a youtube vid with a disco pump making the same noise,any ideas what the problem could be?
atb paul
[url] [/url
Post #457650 24th Sep 2015 4:12am
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
I had a similar issue but the noise wasn't the same as your vid.
Check on my problem and noise here http://www.defender2.net/forum/topic38392.html
For me I changed the injector seals and washers which resolved the problem completely. She started perfect after priming and no noise
Mine was air in the system but was more like a wailing cat! 2006 Defender Double Cab- Zambezi Silver
Post #457662 24th Sep 2015 6:29am
Triggerfinger
Sounds like its drawing air or low fuel pressure maybe the fuel pressure regulator or blocked fuel filter.
Check fuel lines for fractures Or pump is on it way out?? O the joys of having a land rover Whistle
Post #457702 24th Sep 2015 10:23am
Laurie
I've got one that can be heard from 50 yards away. Works perfectly, just noisy.
Replaced it in the end. No noise now.
Anyone want a TD5 Ninety fuel pump cheap?
Post #457705 24th Sep 2015 10:38am
foxing
Wales
thanks for the replies,will try the fuel filter then the injector seals,the joys of owning a defender Banging Head
atb paul
Post #457922 25th Sep 2015 4:21am
