Home > Maintenance & Modifications > Ashcroft Transmission's new HD P38 Diff replacement. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
Dave,
This looks like a very interesting development! Is the shorter propshaft that is required with this diff one that is available as standard on a different Landrover, or is it necessary to get one modified to suit? Will you be selling compatible propshafts? Also, how would you rate the new diff in terms of strength compared to a standard P38 with an Ashcroft HD ring & pinion set (presumably the new diff is much tougher), and to a Rover pattern diff with an Ashcroft R&P set? Finally, what sort of figure would you be looking at for an outright sale for one of these with an Ashcroft ATB fitted, together with a propshaft? I have one of your ATBs with HD ring and pinion in the front axle of my 110 and was planning at some stage to upgrade the rear to a P38 with ATB and HD ring and pinion, but I am now thinking that this new diff might (subject to the price) be a better option. What would you recommend? Thanks, Roger |
10th Jun 2013 9:01am |
Drover Member Since: 27 May 2011 Location: Central Coast NSW Posts: 53 |
Finally got the old P38 centre out today and fitted the the new HDP38.
Here is a comparison pic of the two nose to nose. [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
15th Jun 2013 7:45am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I love looking at stuff like that
15th Jun 2013 8:40am |
portal pat Member Since: 05 Jan 2015 Location: South. Very south. Posts: 36 |
Where is this a assembly available in Australia please? Nothing suggests poor workmanship like wrinkles in the duct tape.
22nd Sep 2015 5:21am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
through Ashcrofts Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Sep 2015 10:28am |
You imported it yourself? Nothing suggests poor workmanship like wrinkles in the duct tape.
22nd Sep 2015 12:03pm |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 |
What was your final decision on the prop length? Reading the other post on the atb by tatra805 I am unsure what I need to install. Std or 31mm shorter . Have I miss read somewhere? My setup. 2005 110 Old diff-p38 type New diff-long rover with atb and adaptation plate. I think I have a spare p38 rear prop in the garage but need to check the lenght( it is shorter but maybe too short) Range Rover p38 4.6 99 lpg(gone ) |
7th Nov 2015 3:02pm |
if you are fitting the slighly longer nosed Ashcroft off set pinion diff then you need to take 31mm out of the length.
if yoiur just builing an ATB into a std diff then no change. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Nov 2015 8:54am |
9th Nov 2015 9:00pm |
