Home > Td5 > Constantly Going into limp mode
110MGD
2001 Defender 90 Td5 CSW Epsom Green
As much as I love my old 90 I Am totally losing confidence in it at the moment.
At least one in five times I drive it the EML light comes on and I have no throttle control and have to limp it home or get a recovery out. This is extremely frustrating at quite frankly at the moment I could sell my daily car, and the defender and by another big modern 4x4 or perhaps even go Japanese (X5,Touareg, Land Cruiser, Shogun) as I am losing confidence in Land Rover
However I love the defender and really want to keep it. Does anyone know a definitive list of what could be putting the EML light on? I thought I had cured it with a new fuel filter and the water in fuel sensor disconnected. What other things should I check
Regards 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #456717 21st Sep 2015 7:26am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Ideally you need to plug into a diagnostic machine to read the codes but is sound like a throttle pedal wiring fault, most people use five core wiring to bypass the original loom from the pedal to the ECU, not to big a repair and definitely not something to make you lose confidence as its a easyish one to sort.
Kind regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #456724 21st Sep 2015 7:57am
JWL
To save yourself a whole load of heartache it really needs to have a diagnostic kit plugged in. There might be someone in your area who'd be prepared to meet up and plug theirs in or give a good independant garage a call. Otherwise you could be chasing a simple fault round at great expense plus the time wasted.
Post #456725 21st Sep 2015 7:58am
roel
If you want to keep it, buy an Nanocom. I bought an old one for very little money as it doesn't want to talk to a laptop naymore but it works in standalone so I can read faults and values.
It cost me less than one visit to a Laro Doctor. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #456732 21st Sep 2015 8:16am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Mine did similar, more and more often, usually on a wet day,
I checked the loom from everywhere I could see it, including using a jet wash on the connectors and wiring, but could not reproduce the fault,
So as a fix / elimination I also required the pedal and bypassed the loom untill it went into the ecu, I used trailer cable,
Since then never missed a beat Thumbs Up
So although I have never found the problem it appears cured
Post #456854 21st Sep 2015 4:01pm
110MGD
Thanks for the quick response guys. Doesn't sound too bad then, was sick as a chip and utterly annoyed with it before. Maybe I won't be so hasty now! Mr. Green 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2014 VW UP!
Post #456868 21st Sep 2015 4:52pm
