Home > Maintenance & Modifications > Front recovery swivels |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5864 |
Would anyone happen to have one of these kits http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...567008d909 not installed yet who could kindly measure the cir-clip please?
Mine have got lost. I have tried measuring the groove with the callipers but they don't fit 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Sep 2015 8:20am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Drill correct size hole then pass through the hole and the circlip retains at the front of the swivel simple as that
20th Sep 2015 5:20pm |
On the front on the winch bumper there are two 36mm holes - one either side. Pass the swivel through from the back, and pop the circlip into the groove. This stops the eye going backwards out the bumper. 1999 Defender TD5 110
20th Sep 2015 5:50pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
I have the same question,..how do they attach to the front of a standard Defender. I did see some others that bolted to the top of the standard Defender bumper mounting points with the addition of another two bolts through the bumper, made by a German company GMB or GMP? Pickles. |
20th Sep 2015 10:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
You can't use them with an OE bumper.
You need a FF or D44 HD or similar option. I have a pair on my FF tubular.. First Four sell the circlips off the shelf after I enquired and asked last year. http://www.firstfour.co.uk/item/2171318/re...eye--each- |
20th Sep 2015 10:30pm |
Cheers - just ordered a pair. I asked about 4 or 5 suppliers on ebay and non sell them separately! 1999 Defender TD5 110
21st Sep 2015 7:10am |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
Could try Machine Mart - useful set to have as back-up
https://www.machinemart.co.uk/shop/product...-040210395 NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
21st Sep 2015 7:14am |
I do have a selection but non as big as the swivel eye. I have some 33mm and not big enough 1999 Defender TD5 110
21st Sep 2015 7:22am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Go to the nearest shop were they repair agriculture machines and they will have them in stock is my experience. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
21st Sep 2015 8:02am |
Just checked. Mudstuff stock the front recovery eyes I was talking about,.....they mount onto the top of the bumper using the two original plus another two mounting bolts,..made by GMB,.....look like a quality product to me. Pickles. |
22nd Sep 2015 12:46am |
Got the new circlips today but I think the news ones are a bit small compared to the remaining part of the original one.
Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
23rd Sep 2015 6:13pm |
They get stretched out quite a bit once fitted, you've got the fun bit yet and that's getting them on!
Been there done that and not keen to do it again. I found all my Circlip pliers weren't big enough to open it far enough. They do need to be tight thoough after all. You don't want a big chunk of metal or a shackle falling off, highly unlikely but if no shackle was on it'd be easily possible. Oh bad stealable. |
23rd Sep 2015 6:35pm |
I hadn't thought of the clip being stretched, but comparing old and new there is quite a stretch! They are fun to get on!! 1999 Defender TD5 110
23rd Sep 2015 7:11pm |
I found once you started them you can slip them back and in the groove not too bad. It's just getting them on first.
23rd Sep 2015 7:25pm |
