Home > Td5 > Front lower door seals
excossack
I have a pair of the L shaped door seals such as these > http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...2083673305
How far from the door panel does the seal sit? or does the seal sit up against the door panel? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #456328 19th Sep 2015 2:44pm
roel
I just installed them too. I have 1984 doors in my td5. The parts with the holes is flush with the steel part off the doors. So the part without the holes comes from about the middle off the door to the inner side off the door and seal against the floor structure.
I am not sure if the is clear.
But It did it different. I made them on the floor-structure and sealing against the door. I am not sure if this is better or not. Mr. Green
Early models, the seal was on the body. Later models the seal was on the doors. I don't know where the changeover was. Somewhere between 1984 and 2003. Whistle Roel
2003 90 Td5 (2009-now)
Post #456375 19th Sep 2015 6:46pm
excossack
I think I am with you. If you are passing by your doors with a camera - could you take a pic please? 1999 Defender TD5 110
Regards
John M0VAZ
Post #456381 19th Sep 2015 6:57pm
roel
I googled and found some pics.
The td5 style seals:
I connected my seals to the piece off metal shown on the btm off this picture:
 Roel
Post #456392 19th Sep 2015 7:26pm
excossack
I should have googled as well - Thanks
That looks about 10mm from the panel side of the door? 1999 Defender TD5 110
Regards
John M0VAZ
Post #456399 19th Sep 2015 7:50pm
roel
I'll check tomorrow where the poprivits are in my old td5 door are located. Roel
Post #456427 19th Sep 2015 8:43pm
roel
Some pics:
I measured were the pop-rivuts were on the original td5 door:
The btm off the door is 3cm between the doorskin and the innerside and the poprivuts are about in the middle.
I put the seal here:
But that is not 100% nice.
It just extends below the door.
I installed them there as I hope it will protect the door more from mud that comes up through the gap between the floor and the sidebar.
Just installed them this week and not been off-road yet so still have to see if it works. Roel
Post #456730 21st Sep 2015 8:10am
