![]() | Home > Td5 > Installing a MUD Dash Console with AC QUESTION... |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Could you trim off the excess? 1999 Defender TD5 110
If I remember right there is either a clip or screw in a hole if you look up from the base of the gear stick to the bottom of the air con panel and when this is removed the whole panel will sag in the middle so you can slot the console in and then put it back together. Ray
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Monsieur le excossack that is plan B! Mk1collector your rmemory is absolutely correct, you gotta get down really low but its there... I don't know how I missed that. Perfect, thanks a bunch.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
