![]() | Home > Tdi > Think I Have Found The Coolant Loss Fault :( |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Very generous offer Slim, Thank you
![]() I will take it apart slowly and then have a look and see what we find. In the mean time if a good one comes available I will pounce on it ![]() Self confessed mileage hunter ![]() |
Haha, I'd love an evening project once the immediate issues are solved Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Thanks Slim
![]() I am confident and competent to do it, its just gee'ing myself up for it. Especially now the evenings are cold and dark. First challenge is shoving it up the drive so I can work on it close to the workshop rather than half way down the drive blocking everything in. ![]() Self confessed mileage hunter ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
ah shags, its looking poorly!!! get the head of quick b4 the cold weather and dark nights come! you will do it in a weekend!
![]() my youtube channel |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
I wouldn't be too worried about leaving the head off for a few days, when I did my SIII the head was off for probably close on a month while I did the work to the head, I just gave the exposed parts a spray with WD40 and left an oily cloth over the block to keep any bits out. All went together well and no problems.
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Yep the head gasket is gone - the replacement will look different so don't worry. I had the same on my 200TDi - not a complicated replacement....I did mine without any problem I just followed the instructions in the RAVE manual to the letter. I suggest you replace the head bolts at the same time and follow the torque sequence with the angle guage carefully.
